-   -   Help Blinker/Hazard Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/353960-help-blinker-hazard-problem.html)
evylu2002 06-25-2007 04:14 PM
Hello All,
I encounter the following problem with my turning/hazard signal lights. I searched the forum but didn’t find appropriate info. So I describe my problem.
Hazard on /Ignition off = 4 lights (left/right/front/rear) and red light in switch light continuous. Indicator lights do not light. When I remove the blinker relay the result remains the same.
Hazard on/ignition on = all abovementioned lights (5x) blink normally. No indicator lights
I changed the blinker relay for a new one with the same results.
Possibly someone encountered the same problem.
Thank you for your advice and tips.
Regards, Ko
