Carpet layout for a 911sc
Hi all,
I bought a carpet set from appbiz on ebay and though I am happy with the quality, there are several pieces that don't seem to match the factory stuff...does anyone have a layout of 911sc carpet...how it should go in etc. Any experiences with the appbiz stuff?
Rob L.
Currently have too many cars
to properly care for
Old 06-28-2007, 12:20 PM
Driving member
jester911's Avatar
Did you remove carpet from your car?
I did the appbiz kit a couple years ago and my method was to label each piece as I removed it. Then match up the new pieces with the old. Some of the pieces need to be cut and fit such as the kick panels over the fans in the front foot wells and the panels under the rear windows.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 06-28-2007, 12:25 PM
Work in Progress
Rich76_911s's Avatar
This tech article might help:
http://www.pelicanparts.com/techarticles/911_interior_restoration/main2.htm
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 06-28-2007, 12:28 PM
Carpet
Guys,
Unfortunately, I did keep many many of the pieces and drew a diagram but some of the pieces tore as they were water damaged and essentially rotted.
I am assuming some of the appbiz pieces need cutting on, such as the gear shift/heater handle pieces...the stuff doesn't seem like a perfect fit in all honesty...the pockets for the kick wall by the pedals seem impossible
Rob L.
Old 06-28-2007, 12:36 PM
Super_Dave_D's Avatar
Heres a thread that might help you out
Carpet install
Also - Google for 'classiccarcarpets'. As one of the top results you'll find a pdf-file withe the installation-procedure for your carpet.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 06-28-2007, 12:55 PM
