-   -   Double check your torque settings before you grab the wrench! (http://forums.pelicanparts.com/porsche-911-technical-forum/354576-double-check-your-torque-settings-before-you-grab-wrench.html)
Por_sha911 06-28-2007 07:40 PM
Double check the specs before you grab the torque wrench
Pressure plate bolts require 18 foot pounds and not 32.
32 is the trans to the motor spec.
One afternoon wasted and one set of 9 new bolts being overnighted and I'll be back on track. grrrrrrrrrrrrrrrrrrrr.
I'm feeling much better now.
slodave 06-28-2007 07:43 PM
Hopefully you'll get that Omega clip by the weekend :)
Por_sha911 06-28-2007 07:53 PM
This has been one of those projects.... Sigh.
Thanks for all your help.
movin 06-28-2007 10:01 PM
And don't forget to relax the torque wrench spring after you're done by reducing the torque setting to minimum or "stop" before putting it away.
Early_S_Man 06-28-2007 11:25 PM
Could be worse ... you might have to be waiting on a new set of 9 mm rod bolts like at least one Pelican did after using the M10 spec on the M9 bolts in his 3.2??? Yield testing your fasteners is not a fun thing to do when you would just like to get the car running again!
