How to ID chain tensioner upgrade on 2.2?
As a previous SC owner I am little unsure how to ID the chain tensioner update on a 2.2 motor (70T). Is this it?
Ulrich
Old 08-12-2007, 05:04 PM
Evolved
Mo_Gearhead's Avatar
No
The line from the block to the cam tower will have another line that runs to the middle of the chain cover ...if its an upgrade.
Don't fear the reaper.
Old 08-12-2007, 05:05 PM
This is what it would look like, installed. Right side. (Photo thanks to Pelican)
The tell-tale sign is the small oil line going to the cam cover. You will see it on both sides.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-12-2007, 06:02 PM
HarryD's Avatar
Ulrich
Those are non Carrera tensioners but the other question if the ones you have are the old ones or the later Turbo ones. The only way to know is to remove the chain covers and check the tensioer part numbers.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-12-2007, 08:20 PM
