-   -   Is something missing here? (http://forums.pelicanparts.com/porsche-911-technical-forum/354853-something-missing-here.html)
BeyGon 06-30-2007 01:07 PM
I got this back from a shop a couple weeks ago and was checking under the lid today, it looks like something, a cover, is missing but I can't remember if there was something there and if so, what it looked like. I just looks like it should have been covered and I don't remember seeing it so open. I can't find a picture in any of my book that shows that area, so, what do you think?http://forums.pelicanparts.com/uploa...1183234022.jpg
slodave 06-30-2007 01:11 PM
There is a plastic cover that goes over that area.
jbrand540 06-30-2007 01:21 PM
Not sure what year you have 84-89? But here is a link to a diagram that shows the cover for 87-89. Part number is oem-91161010504
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_87_89_KATALOG/902-00-Frame3.htm
rgdalacrity 06-30-2007 01:31 PM
Why am I not surprised that the shop left something off?
BeyGon 06-30-2007 01:40 PM
Thanks, it is an 89 and I will go in Monday and check on it, the area just looked so different and I wanted to be sure before I go back.
rnln 06-30-2007 03:51 PM
Not sure if your car has ie before you bring it in but there should be a black plastic cover there to cover the whole area (big). The little square red bracket you see in your pic is where the top bolt mount to.
shbop 06-30-2007 07:08 PM
Be careful to avoid grounding the fuses, until you get the cover back on.:)
MattAlpha 06-30-2007 07:43 PM
You can tell that the cover hasn't been missing for long due to how clean that area is.
BTW what kind of work was the shop doing that they needed to take the cover off in the first place?
-MAtt
BeyGon 06-30-2007 08:26 PM
-MAtt
The idle would surge, go up to 2500 and stay, I could flip the throttle and sometimes it would drop, sometimes not. Sometimes it would die at a stop, it is missing the cover but the idle stays constant. So, I don't know enough to know why the cover is off.
Gogar 06-30-2007 08:37 PM
It's likely they took the cover off to get some power for a timing light or engine analyzer.
jbrand540 06-30-2007 08:37 PM
They would have probably had to jumper the ICV in order to test/diagnose/adjust the idle.
The black rubber circular port in the metal panel right in front of the ignition coil is what they would have been accessing.
Makes you worry though if they missed something that obvious what else may they have forgotten.
rnln 06-30-2007 10:16 PM
BeyGon,
I hope you don't might I use your pic to ask everyone a question abou the top fuse. This pic look the same as my 87/88 but mine doesn't have the top fuse.
Anyone know what it's for?
Gogar 06-30-2007 10:21 PM
Rear window defogger and "rear wiper return"?
rnln 07-01-2007 01:17 AM
Thanks Gogar,
Make sense, since my car is a cab.
Gunter 07-01-2007 08:27 AM
Make sure you'll also get the 2 wing bolts along with the cover. :)
Don't let them jamm sheetmetal screws in there! :(
