Throw it on the ground!
Joining the polished fan club!
Whew, that was a lot of work!
Before
After. Now I need to get the plastic nut cover from our host to finish the project (911-603-127-00).
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 12-31-2006, 01:14 PM
Danny_Ocean's Avatar
Fan-tabulous! Procedure?
Old 12-31-2006, 01:18 PM
Zeke's Avatar
Manifolds are next.
Old 12-31-2006, 01:24 PM
My makeshift polishing station below. Started with the wire wheel on the fins......mine were fairly pitted. Then 320 to 600 grit wet paper using WD40 followed by tripoli and white polishing compounds. Finished with mothers.
Have fun!
Mark
1987 911 Coupe
Old 12-31-2006, 01:41 PM
Diss Member
Quicksilver's Avatar
I had a polished fan...
and then the realities of magnesium combined with oxygen in the atmosphere reared its ugly head...
Now I would hit it with the Gibbs penetrant. http://www.roadsters.com/gibbs/ It will make it darker but it will also make the polish last.
Look here for an unpolished example:
Powder Painting Magnesium
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-31-2006, 02:06 PM
Czar of C.R.A.P.
dfink's Avatar
Just got done with mine will post pics tomorrow. I also cleaned the fan housing. I used some simichrome on the fan and housing don't know if that will help protect or not. Mine were painted a couple years ago. The paint really gets in the poors of the metal was a pain to get clean. I used up 6 dremel wire brushes. I also cleaned (scotch brite wheel) the stainless heat exchangers. With the Fabspeed cat the HEs and the polished fan If I can't catch them with speed I will just blind them with the flash then pass while their eyes are closed. Ha....
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 12-31-2006, 03:39 PM
Looks Great!
Drums
'89 G50 w/ 3.6 V-Ram-now Ca. legal!
FORMER Yosemite Chapter PCA V. P.
Old 12-31-2006, 05:07 PM
Use the Gibbs or your work will have been a waste.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-31-2006, 05:17 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
WOW...beautiful job...is it hard to keep it clean after...?
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 12-31-2006, 05:31 PM
Yes.
Stephan Wilkinson
Old 12-31-2006, 09:10 PM
Easy to use. It should be a done deal for everyone.
It's almost like shooting WD in pia areas to rejuce the fan of the original shine. It's not a polish it's a preservative and easy to use. + There is no sharp cut from ok to FU as it weakens.
I've seen that happen.
ps: It doesn't leave as much of the mirror as concours products but it lasts just as long if not longer and concours is a lot more work..... all imo
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2006, 11:37 PM
Re: Joining the polished fan club!
It looks like you painted a picture. It's just rewards.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2006, 11:47 PM
I did mine,and after a month it became gray again. But a friend of mine put future floor wax on the fan and housing,and after a few years it's still very nice.
Daniel
Old 01-01-2007, 02:58 AM
Interesting. Future is near-universally used by serious scale modelers (my winter hobby...) as a sprayed-on coating over the airbrused paint that makes much of the difference between a true display model and a toy. Future, it turns out, is nothing but pure, colorless, very tough acrylic.
Stephan Wilkinson
Old 01-01-2007, 07:02 AM
kilodawg's Avatar
I just got some Gibbs last week after seeing it mentioned on the engine thread above. The stuff works great. Unlike any other product I've tried. I use it on my Ti road bike too. I doubt I'll be without it from now on.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 01-01-2007, 07:10 AM
Czar of C.R.A.P.
dfink's Avatar
Shiny bits as promised
Fan and housing
Stainless heat exchangers
66 912 Coupe
Old 01-01-2007, 03:36 PM
Dfink, nice work! How did you get into the groves on the outside of the fan housing? I started to do mine but one of the alternater bolts broke so I'll do it later.
Mark
1987 911 Coupe
Old 01-01-2007, 05:30 PM
Czar of C.R.A.P.
dfink's Avatar
The little 1" stainless wire brushes in a dremel drill with a flex shaft. It wound up taking 6 of them to get it done. A very small grinding stone will then get into the left over corners. The process would be easier if it had never been painted. Even the application of the simichrome polish dulled the finish. I didn't get quite the finish that you did under the assumption that it wouldn't last anyhow. I think I will order some of the gibbs and just hit it all with that.
I have thought about shining up the upper valve covers also. For the love of God I must get my engine parts back so I quit doing this.
66 912 Coupe
Old 01-01-2007, 05:56 PM
Dan in Pasadena's Avatar
Has anyone tried using the acid type wheel cleaner they used to sell (do they still?) for cast finish wheels? Probably as a first treatment to remove all the gunk from the fan and housing?
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 01-02-2007, 02:53 AM
durn for'ner
livi's Avatar
Probably an imbecile question but, is there a functional aspect to such cleanliness or is it merely for show?
Impressive work in any case!
Markus
Resident Fluffer
Carrera '85
Old 01-02-2007, 04:23 AM
