3.0 sc engine into a 77 911s questions..
1.Any help out there for wiring this? engine is in the car.. the main connector is probably ok, but there are other connectors I'm not sure of.. Is there a resource for this?? Also, I have a msd 6al, which will further add drama..
2. The oil line at the rear of the sc engine (which has a full catalytic exhaust) doesnt seem to match to where the old hard line connected.. the car does have a front cooler.. Is there a hose that mounts to connect the two?..
Any help on any of this i would appreciate.. Its a special 3.0 with 964 cams
Thank you
Old 07-01-2007, 10:53 PM
I did this with a '75 body, and there are some wiring changes in the multi pin connector (at least for '75). I'm not sure if my info will help you, but I think I have a pin map. The fuel pump runs constantly on the '75, the '78 engine has the flap contact to shut it off which does not work on the '75. One thing I have not yey fully figured out is that the vacuum cutoff to the lower port of the WUR does not seem to work correctly with the '75 wiring. I had planned to post about this, but haven't yet.
I did not find any cookbook for these swaps during my effort a few years ago. I was surpised there wasn't any info.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 07-02-2007, 05:28 AM
