-   -   VDO clock vs. Voltmeter (http://forums.pelicanparts.com/porsche-911-technical-forum/355037-vdo-clock-vs-voltmeter.html)
Thrasher 07-06-2007 07:54 AM
one caveat would be that if you use the cig lighter cord, you may not have an ideal connection if you want super-accurate readings. If that's the case, you can always hard-wire your 8500 to a suitable wiring location to get a more accurate reading.
dshepp806 07-08-2007 04:27 PM
rlh930 :
Yep,..she 's working great....compares nicely with digital meter applied to cig lighter..happy there. As well,..it appears to (surprisingly) remain comparable to the actual battery posts...even happier,..ALL finalized with my trusty Fluke!!! Nice to ditch the bulky DC adapter...Guess I read a bit too much-too fast sometimes......thanks, again, for the heads-up...
My best,...
Porsche_monkey 07-25-2007 07:58 AM
Slightly less elegant than some of the other choices, but for $6.99 I can live with this. And it is the best lit gage in my car at night. (No suprise there. :rolleyes: )
http://forums.pelicanparts.com/uploa...1185375500.jpg
84porsche9113.2 07-25-2007 11:00 AM
I like gulf908's idea and picture (from page 1 of this thread) of using a factory porsche part (clock blank). Problem is, at least one website (see below) says this part is no longer available from porsche. Anyone have a part number and/or can confirm whether or not it still available from porsche??
Also, if anyone has bought one of these, what was the cost? (I'm just curious how much porsche would charge for a 3" piece of plastic - even if it is no longer available).
http://www.eurocars-uk.co.uk/partsforsale.html#_self
84porsche9113.2 07-25-2007 12:08 PM
By the way, for anyone looking for a "super easy" install digital voltmeter, this appears to be the one.. Only $53 at JC Whitney, and digital too... No need to mess with wires or brackets. Although I don't have any personal experience with it, so I can't really endorse it, I am considering one...
-Does anyone know if this will fit the porsche cigarette lighter (are porsche lighters and other car lighters the same size??)
http://forums.pelicanparts.com/uploa...1185390455.jpg
Edit - Regarding the warning feature of the passport, I thought others would like to know that this gauge has something similar. Description I found from a different vendor is as follows.
"Plug-in style. Features scrolling 'Hi' warning if voltage reaches 16 V and scrolling 'Lo' warning if voltage reaches 10 V. Not available with memory feature or adjustable low 'gauge flashing warning'."
SCWDP911 07-25-2007 12:49 PM
Originally Posted by xiat (Post 3358245)
I called and talked to VDO in North Hollywood. $225 bucks to integrate the voltmeter into the tach. A little spendy but it sure looks cool.
Roger
Man, bummer... I really like that look too and always wondered what the charge was to get it. Guess I will have to put that one on the backburner for awhile.
Sure looks good though! Maybe a good birthday present this next year. I will have to start leaving hints for the wife and kids around the house...
rennch 02-21-2017 01:01 AM
This is an OOOOOOLLLLD thread, but I'm in the market, as my clock is toast. I've just realized I have an old school speedo place a block away from my house. I might stop over and see what they have for a solution. Will keep you posted.
RNajarian 02-21-2017 02:37 AM
Here is a more recent Voltmeter Discussion
Here is a link to a more recent Pelican discussion on Voltmeters
My solution is post #56, but there quite a few other creative options. Have a look, I think you'll get some good ideas.
http://forums.pelicanparts.com/porsche-911-technical-forum/866360-danger-install-volt-meter-now.html
