Integrated Voltmeter cost
Roger |
Type911, really like your solution. At the risk of exposing lack of knowledge, how is the volt portion hooked up? thanks. Lynn
they will do it internally so it will hook up the same.
Re: Integrated Voltmeter cost
To gulf908:
Is your unit one of the three I posted in my earlier thread. Here's a post that offers easy comparison--> cockpit: http://store.summitracing.com/partdetail.asp?autofilter=1&part=VDO%2D332041&N=70 0+4294822101+4294900134+4294782479+115&autoview=sk u This is 2 1/16" ( 52mm) and edge-lit. pro-cockpit: http://store.summitracing.com/partdetail.asp?autofilter=1&part=VDO%2D332601&N=70 0+4294822101+400267+4294765776+115&autoview=sku This is 2 5/8" ( 67mm) and edge-lit. Vision: http://store.summitracing.com/partdetail.asp?autofilter=1&part=VDO%2D332103&N=70 0+115&autoview=sku This is 2 1/16" (52mm) and backlit including needle backlighting. No 67mm version of this type is available. The reason I ask is that the "Vision" looks best to match the OEM instruments, but it's backlit and wouldn't match the lighting of the OEM gauges. The other two ( I think) would match by using perimeter lighting. Correct? To Jazzbass: Here's a question on your method. Looks like we can turn your gauge 90 degrees clockwise, and have the readable "band" at the top of the gauge. Inside we can place the guts and face of the 2 1/16" gauge or the guts and face of the 2 5/8" gauge. The bottom band can be "blank" or we can use something else in it. In any case, which "radius" of the band would work better...the 2 1/16" gauge or the 2 5/8" gauge. All we would then need is a junk fuel level gauge. ( In re-reading your answers..it appears a 2 1/16" gauge was used. Maybe simply confirm.) - Wil |
OK PBH.....are you serious? What do you do at night ? Thanks for the insight....
- Wil EDIT...maybe I misunderstood. I'm saying if you install the Vision in one piece ( like gulf908 did)...it has lighting that doesn't match the other gauges. If you mean I'm using the cannibalized guts in the other method like Jazzbass....then OK...I think I see your point. Sorry. |
Wil - you can use the 2 1/16th gauge. In fact, I made the gauge markings that are in there by scanning the original gauge face, turning the numbers in Photoshop, and printing the result out on photo paper. I made sure the graduations were exactly the same as the 2 1/16th gauge. Turning the gauge so the volt part was at top would be simpler and make more sense, actually. All you have to do is cut the original face of the 2 1/16th down so it physically fits.
Westach made me a combo volt and CHT meter to replace the clock....150 bucks.
Will,
I bought the gauge a long time ago and have had it in my previous Carrera before this car. It sure looks like the #3 gauge which fits in with the other dial colourings for '71. The lighting is a little brighter/whiter than the OEM gauges but I tell myself the other dials are 36 years old now,but even so the relative difference in brightness is not all that material. HTH Cheers, Dennis. :) |
Another thought...
If you take Gulf908's approach and insert an aftermarket gauge in a clock blank face... but use the larger 67mm gauge ( 2 5/8") instead of the 52mm ( 2 1/16") gauge....you get a look like Jwetering has here---> http://forums.pelicanparts.com/showthread.php?s=&threadid=243605&highlight=clock+ delete Of course, the Autometer device Jwetering shows is no longer available with a black bezel, only brushed chrome. And...VDO does not make the "Vision" in this size ... :( - Wil |
my personal favorite, and it's still very visable on the top of the console stack without moving my knees.
(1.5 inch Stewart-Warner) Bill K http://forums.pelicanparts.com/uploa...1183652090.jpg |
Maybe w/o having to move your knees.....but no doubt you have to move your eyes or head downward. As I mentioned before, looking for a solution that places an *important* gauge like this one in plain sight along the main instrument panel. If need be...I'd then put a 1 1/2" clock down there, like you did. Must say, however, it does look neat and tidy.
My last post showing a 2 5/8" ( 67mm) unit in the clock blank is to show the relatively shallow "rim" that results compared to Gulf908's approach using the smaller gauge. Just my opinion...... - Wil |
Wil, you can argue this till you're blue in the face.
I personally don't think the volt reading is as 'upper level' worthy as what the factory already put there. I check to see where the battery charge is before cranking and occasionally during a run to see how the alternator is doing. I like it there out of the immediate line of sight, and it takes no more moving of the eyes than checking oil pressure and temp once you're used to it. Bill K http://forums.pelicanparts.com/uploa...1183659147.jpg |
From p. 17 of the 8500 X50 manual : Pilot V (Vehicle voltage) In this setting, Passport will continually display “H” for Highway, “C” for City, and “A” for Auto, and the vehicle’s voltage. If the vehicle’s voltage drops below 10.5 volts, a low voltage warning is displayed, followed by an audible alert. A high voltage warning is also given if the voltage goes above 16.5 volts. The high-voltage warning is also followed by an audible alert. |
Thanks Thrasher,..my p. 17 doesn't show this feature. It's a manual for mine dated 2004. A review of the data I have unsurps any such feature on my (dated?) version. What's the production year of yours? Sounds like a nice, usable feature...wish I had it!!!
Best, |
my bad,..
""""""A review of the data I have unsurps any such feature on my (dated?) version. """""",..should read: A review of the data I have unsurps no such feature on my (dated?) version. """""""""""""" Sorry. DS |
rlh930:
Those pages brought me home,..thanks! I shall now go try it As well, my 'best' to your "5-year-old"///........... |
Hey bkreigsr:
I'm not arguing "till blue in the face"...I think I signed off my last post with "just my opinion". Which it is. - Wil |
| All times are GMT -8. The time now is 05:59 AM. |
