supercarrera82's Avatar
max rim size for 82 porsche 911 sc????
I have been looking at post after post and i keep getting more confused, i was curious as to how large you can go, i was interested in 18" wheels for a narrow body, what offset along with max width can i go with front and back???? any one ever try this? Please let me know thanks
Old 07-01-2007, 05:58 PM
Here is mine with 17"s, the wheel didnt have the proper offset so I am running good spacers with no issues so far.
think 18"s would be close to the wells. I think there is an 80ish SC here with 18"s or 19"s
Old 07-01-2007, 06:08 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Get rid of those center caps and those wheels would look great.
Was gonna get a set of ROH's but found a set of BBS's a day before I was gonna pick up the ROH's.
18's will fit, but barely, you may have to make some suspension changes in order to fit the larger wheel.
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 07-01-2007, 09:16 PM
rnln's Avatar
Originally posted by fty
18's will fit, but barely, you may have to make some suspension changes.
Can you explain a little more detail into this area? What will be the problem and which part need to be changed?
Thanks.
Fat butt 911, 1987
Old 07-01-2007, 10:37 PM
fty fty is offline
fty's Avatar
Ebay wheels (pics). Anyone has modern wheels like these on older 911?
Check this thread out.....
Old 07-01-2007, 10:44 PM
ne one know the offest you would go with if you run 9's in the rear or even 10's in the rear if possible on 18" wheels????
Old 07-02-2007, 09:43 AM
fty fty is offline
fty's Avatar
I have 16" x 9's in the rear with 245/45 tires with no clearance issues running a 23mm offset, hope that helps.
Old 07-02-2007, 10:38 AM
Bill Verburg's Avatar
Re: max rim size for 82 Porsche 911 sc????
Whether you have 15, 16, 17 or 18" wheels doesn't matter, they all need the same o/s.
In the front 8" o/s +23.3 to +31mm
In the back 10" o/s +15 to +20
The more you push the limits of width the less o/s tolerance and the more work needed to fender lips, oil lines and suspension components.
If I was you I would limit my search to 8" ~+26&#177 and 9" ~+15
What others have used can be found here
Bill Verburg
Old 07-02-2007, 11:08 AM
I run 8's and 9's on 18''s
18x8 front with 5.5" backspace (25mm offset)
18x9 rear with 5.5 backspace (13mm offset)
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 07-02-2007, 11:38 AM
Trying to find a nice center for the ROHs, thought about a porsche center gel decal but havent found any...
Old 07-02-2007, 12:53 PM
fty fty is offline
fty's Avatar
Just get rid of them.. Look like a bigger dia. without the center caps.
Old 07-02-2007, 02:58 PM
With the caps off they look unkempt and ragged...
Old 07-02-2007, 03:00 PM
