Oil Temperature Sensor / Sender....question...
I received my new numeric oil temp gauge, and sender.....question is: Do I have to drain oil to remove the old sender and install the new one, or, on a cold motor, can I remove the sender without having a gusher?
TIA |
no. i would do it on a cold car. but then again, i hate pain.
Nape I just did my conversion yesterday on a hot car ;) like vash said there is pain involved when its hot lol
easiest conversion i have ever done and the most enjoyable... did you have this issue when you changed over? Click on the link http://forums.pelicanparts.com/porsche-911-technical-forum/355626-numerical-temp-gauge-change-question.html |
Frank....
I haven't tried it yet.....I was planning on doing it tonight.....the car is cold, my real question was "If I do not drain the oil, when I remove the old sender, will it leak oil?".......
Now I will look more closely at your link to see what I may experience...... Is the gauge an easy job? What is required? Thanks, Mark |
Nope you'll be fine. I took my oil sender out for repair after nicking the windings while fishing out multiple dipsticks from the tank (long story). When cold, the oil level drops below the senders "hole" in the side of the tank. Even the workshop manual says you can do it without draining tank.
Jon |
Thanks Jon....
exactly what I was hoping for......much appreciated.
| All times are GMT -8. The time now is 11:23 PM. |
