Nape75'911T's Avatar
Oil Temperature Sensor / Sender....question...
I received my new numeric oil temp gauge, and sender.....question is: Do I have to drain oil to remove the old sender and install the new one, or, on a cold motor, can I remove the sender without having a gusher?
TIA
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 07-05-2007, 07:10 AM
vash's Avatar
no. i would do it on a cold car. but then again, i hate pain.
poof! gone
Old 07-05-2007, 07:23 AM
FenderGuy's Avatar
Nape I just did my conversion yesterday on a hot car like vash said there is pain involved when its hot lol
easiest conversion i have ever done and the most enjoyable...
did you have this issue when you changed over? Click on the link
Numerical Temp Gauge change and question
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 07-05-2007, 07:33 AM
Frank....
I haven't tried it yet.....I was planning on doing it tonight.....the car is cold, my real question was "If I do not drain the oil, when I remove the old sender, will it leak oil?".......
Now I will look more closely at your link to see what I may experience......
Is the gauge an easy job? What is required?
Thanks,
Mark
Old 07-05-2007, 07:46 AM
Nope you'll be fine. I took my oil sender out for repair after nicking the windings while fishing out multiple dipsticks from the tank (long story). When cold, the oil level drops below the senders "hole" in the side of the tank. Even the workshop manual says you can do it without draining tank.
Jon
Old 07-05-2007, 08:24 AM
Thanks Jon....
exactly what I was hoping for......much appreciated.
Old 07-05-2007, 08:55 AM
