Throw it on the ground!
Is this plug fouled out?
Car developed a sudden rough idle yesterday and significant loss in power. Problem diagnosed by pulling plug wires while running - no spark at number#6.
I ordered new plugs, cap and rotor yesterday from our host. Had the alternator out last weekend and noticed some corrosion on one of the cap terminals so figured it time to replace. I pulled a couple of plugs this AM. No 6 and 5 shown below. What do the condition of these two plugs indicate? Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 07-04-2007 at 04:13 PM.. |
Somatic Negative Optimist
Mileage?
Never rebuild? Excessive valve guide wear? Compression/Leakdown?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
#6 is fouled something awful. Are you sure you didn't drop that in the mud before you took a picture?
#5 looks good. I can't really tell the color too well.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
Looks like the time I accidently cooked a Hot Pocket (tm) for 20 minutes instead of the usual 2. Blaaaaaaack Pocket!
Here is a pretty good site that helps with analysis of plug condition. http://roadstarclinic.com/content/view/70/127/ |
#6 looks oiled up and not fouled in the typical sense from too much fuel. #5 looks OK but needs a brushing from what I can see.
You might want to consider having a compression and/or leakdown done.
Tony G 2000 Boxster S |
A different view perspective is needed but based on what I see here there appears to be trace amounts of oil entering #6. Isn't the firing order 1,3,5? I don't think #5 is oil related.
"The greatness of a nation and its moral progress, can be judged by the way its animals are treated." M. Gandhi 1977 911S...sold; 03 F20C; 2009 VW Jetta Sportwagen |
never rebuilt Valve guides worn for sure - oil consumption 1qt every 600 miles Compression/leakdown not done yet (need to do it)
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Well, this starts to explain your oil consumption.
How do the others look? Did the car start running better with new plugs?
Switch #1 injector with #6. Or better yet pull the #6 injector and have someone photograph the stream/spray and post. Use caution too!
New plugs don't arrive from Pelican til Friday and don't plan on doing anything till I get the new plugs in. I've only pulled 2 so far so don't know the condition of the others yet.
crusty burnt on oil deposits on both plugs. top end rebuild time. oil use is usually pretty high when you see something like that, maybe a quart in 300 miles or thereabouts.
Oil Fouled Symptoms of oil fouling include black oily coating caused by poor oil control. This situation is more severe than what is seen with the ash-fouled spark plugs and usually represents advanced engine wear. When the oil enters the combustion chamber and covers the core nose of the spark plug, the spark no longer arcs across the gap. Rather it takes the easier path to ground by tracking down the oil on the core nose. This results in a complete cylinder misfire condition. Check for worn valve guides, valve stem seals and/or piston rings. Replacing the spark plug may help for a short time, but the new plug will soon foul.
RSR Seal Installation Thanks!
It is time to do some work to that engine and save some $ - if you don't soon, then it might be really expensive...
cheaper and less hassle to buy time with a few quarts of oil and a few sparkplugs. keep the plugs and plug changing tools in the car. the seals that are on there now may well be still flexible, but the valve stems move around so much in the worn guides that the seals can't keep a decent contact around the valve stem and oil gets sucked in. so new seals are kind of a waste of time in a case like yours.
AutoBahned
and remember the valve is cooled in part thru the stem
loose stem = minimal heat transfer away from stem = hot stem = weak stem (maybe =) broken stem = big piece of metal bouncing around in the combustion chamber = big money & maybe big big big money (new crank) |
4 & 5 looked the same. Idle seem a little higher than normal on test start-up (1,100 vs 900???) Just checked PO service records....these plugs have 45K on them. Holy crap.....plug changes are somthing else in these cars! Had to pull A/C compressor aside to gain access. No plug tool in tool kit.......duct taping std plug socket to swivel adapter and 3" socket extension worked well along with using a 6" length of 3/8" OD fuel line over plugs to get threads started. Great tips from the boards! Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 07-05-2007 at 09:15 PM.. |
It is all part of the learning curve... it gets easier as you go.
Senior Member
As well you might want to keep the RPM's down until you do the valve job. Not saying to keep it under 3000 RPM's but would not take it ANYWHERE near the redline either.
As posted above by RWebb, part of the heat transfer from the combustion chamber goes through the valve stem to the valve guide and into the head. If your guides are loose enough to allow a lot of oil like this into the combustion chamber and foul the plugs, then its also loose enough to not center the valve completely everytime the valve closes. This causes more wear on the valve head and seat as well as more stress on the valve stem. Drive the car as needed but the longer you drive it, its possible the overhaul costs can get higher, sometimes much higher. If its driven long enough that a valve stem breaks and ruins the head, piston and cylinder (and possibly the crank and case as well) then your costs go sky high.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
