ROW 1987 carrera.....whats the difference in spec?
I have my eye on a german import G50 carrera
Does the ROW 3.2 have a higher spec? The owner says it lacks a CAT so I assume it makes marginally more hp Also is it a good candidate for a steve wong chip? Lastly it is a non sunroof coupe....why do some people say that these are more desireable? Is there really any difference in torsional rigidity or weight? Thanks |
I have a 87 G50 without a cat from factory and it has 231 hp. The ones with cat also have 231 hp but feel a little diffrent. I think only the US versions had less hp.
Cheers, |
No sunroof = adequate headroom.
- Wil |
Usually, a Euro car will have fewer options, but this is not always true. It's easy enough to figure out what options it has. The owner says it lacks a CAT so I assume it makes marginally more hp. Yep. Roughly 15 more, give or take, compared to the later US Carrera. Even more, compared to the early US Carrera. Also is it a good candidate for a steve wong chip? Not in my opinion. I'd leave it alone. Lastly it is a non sunroof coupe....why do some people say that these are more desireable? Is there really any difference in torsional rigidity or weight? There is a difference in weight and, on a sunroof car, the extra weight is carried high, which is bad for handling. Can the average person tell the difference? Maybe not. Still, most of us prefer no sunroof. A Euro car will be lighter, sunroof or not, than a US car. Coupled with the higher power, I think anybody could feel the difference between the two, with a little seat time. I value a Euro car much higher than it's US cousin, all things being equal. JR |
Higher HP
Trans geared slightly different for quicker lower gear acceleration No Cat to clog or O2 sensor to foul out (both aren't cheap to replace). Could be a problem if you are in a state that does Emissions testing. No weight up high, no leakage concerns, very desirable if you Autocross (more headroom to get that big, fat, um, helmet of yours :D in there. Steve Wong does Euro chips and he is the man! |
| All times are GMT -8. The time now is 05:03 PM. |
