HKZ Bob's Avatar
Red face Bosch CDI 3 pin experts only
Dear Folks,
I need to replace the Bosch Diodes after the transformer
D7 & D1.
I like you opinion. I am going to use two BY 255 Si-Di 1300 Volt 3A
or two the 1N5404 600V 3A.
I assume both will work.
Does anybody have some experience in replaceing these types. The BY 255 has a bigger pin diameter.
Or would a 1N 4007 will work as well. I ave not measured the
coil back response in value.
Greetings Bob
Old 07-01-2007, 11:22 AM
HKZ Bob's Avatar
I will post the schematic. Just a second.
Old 07-01-2007, 11:24 AM
HKZ Bob's Avatar
Old 07-01-2007, 11:30 AM
HarryD's Avatar
Bob,
I do not know much about this topic but if it was me, I would do a search on CDI and for posts by early_s_man. You will find a wealth of knowledge on this topic.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-01-2007, 01:16 PM
HKZ Bob's Avatar
Hello Folks, who has Data sheet of the original Bosch parts.
Thyristor:
QT104
T6N 500 COB 1 227 030 010
T6N 600 COB AEG 8 925 305 345
Zener Diode
BZY 85/C6 V 8 8 905 421 690
ZX 82 ITT 8 905 421 564
Diode SHG 1SB ITT 8 905 131 051
Diode 0 270 000 003
Diode 0 270 000 001
Diode D1/1000 AEG 9 905 605 701
Diode BAY 38 Valvo 8 905 405 250
Übertrager Bosch 1 224 120 002
Hope you can help.
Old 07-03-2007, 11:07 AM
19 years and 17k posts...
azasadny's Avatar
Wait for Warren (early_s_man) to post, he's the man!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-03-2007, 11:10 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I think both will work just fine. Since the diodes are in series you have even more safety margin here. I would go with the 1N5404 since it is cheap and readily available. After all this is a simple rectifier application.
Good luck,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-03-2007, 11:18 AM
Early_S_Man's Avatar
Porsche Crest
I suggest using 1000 Volt rated 1N5408 rectifier diodes ... there is no difference in cost, and much higher PIV margin. It is far too much trouble unsoldering those 17 wires to risk using a 400 Volt diode at its' design limit!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-04-2007, 11:52 PM
Does somebody rebuild these? I have 2 I would like to fix.
Also, whats the method to unsolder the wires? I tried this once with a cheap solder gun by melting the solder around the wire .... I ended up detroying the circuit bord Then I freaked out and through it accross the room
Old 07-05-2007, 05:22 AM
HarryD's Avatar
LorenFB (who posts here) offers this service. You can also contact Zim's (http://www.***********/acatalog/Rebuilt_CD_Box__911_69_77.html) or Otto's (http://www.ottosvenice.com/) to do an exchange.
Harry
2020 MB E350 4Matic
Old 07-05-2007, 11:19 AM
ischmitz's Avatar
Our host also offers a rebuild service here: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ELignt_pg5.htm
Old 07-05-2007, 11:26 AM
Lorenfb's Avatar
"I would go with the 1N5404 since it is cheap and readily available."
Some seem unaware of the fact that the diodes not only "see" the peak inverter
voltage, i.e. 400 - 500 volts, but also the secondary voltage of the coil if a voltage
breakdown occurs, e.g. coil wire to primary CDI connection or a secondary to primary
internal coil voltage breakdown.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 07-05-2007, 01:45 PM
HarryD's Avatar
Glad to see Wayne offering the service. I did not see that page. FWIW, this service does not appear on the early 911 parts listings. THANKS!
Harry
2020 MB E350 4Matic
Old 07-05-2007, 05:14 PM
HKZ Bob's Avatar
Where to buy these replacement reasonable.
Thyristor: QT104 T6N 500 COB 1 227 030 010
Replace by
16RIA80
25RIA80s
50RIA80 @ $14.30
Zener Diode
ZX 82 ITT 10Watt 8 905 421 564
repalce by
1N 3003 B
ANY ADRESSES RATES
BOB
Old 07-08-2007, 01:28 AM
Tags
cdi
