Targa top question...
Which other years of targa top will fit my '89 (3.2)?
Thanks in advance, Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
THE IRONMAN
84 to 89 for sure...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Really? I thought I read somewhere that they changed it for the last couple of years, but I'll take your word for it!
Thanks, Paul.
Actually, they changed the locking mechanism (roller latches) in `86. So, any `86+ top should fit.
Thanks Eric!
Autodidactic user
I found this document by Dan Petchel in my saved materials. It should help:
Targa Top year differences Tops are not interchangeable except where stated, because body design and Targa top seals differences. 67-68 Thick three finger hinge frame, narrow side seal held with trim piece with five screws, two bare rear metal pins, hook latch, vinyl headliner of soft window and cloth headliner for hard window, fine grain vinyl covered. The soft widow frame was heaver. Tops are interchangeable. 69 Thin two finger hinge frame, narrow side seal held with trim piece with five screws, two bare rear pins, cloth headliner, fine grain vinyl covered, hook latch. Visually different than 67-68 but interchangeable. Narrow over the windshield seal. 70-73 Thin two finger hinge frame, wide side seal held with four screws going through rubber, two bare rear pins, cloth headliner, fine grain vinyl covered, hook latch. Start of thick over the windshield seal. 74-85 Thin two finger hinge, wide side seal held with four screws, three rear pins with plastic sleeve on out side pins, cloth headliner, coarse grain vinyl covered, hook latch. There is a slight difference in front frame design between 74-77 and 78-85 but they are interchangeable. 86-89 Thick three finger hinge frame, wide seal held with four screws going through rubber, three rear pins with plastic sleeve on out side pins, cloth headliner, coarse grain vinyl covered, roller latch. This will not fit later 90-94 cars, any attempted use leads to fly offs. 90-94 Thick three finger frame, narrow side seal no screw holes, heavy steel rain gutter, three rear pins with plastic sleeve on out side pins, cloth headliner, coarse grain vinyl, roller latch. Change in windshields pillar and very thick over the windshield seal makes this top stand alone form 86-89. Dan Petchel CarsincNJ.com Targa top Restoration Vintage parts 609 298 2277
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
Thanks Dave!
Senior Member
Good info to have.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
