sparkplug reading help.
I just changed my sparkplugs and they look like this:
http://forums.pelicanparts.com/uploa...1184189235.jpg The most interesting are number 3: http://forums.pelicanparts.com/uploa...1184189453.jpg and number 5, looks like it been burning oil?: http://forums.pelicanparts.com/uploa...1184189695.jpg The rest more or less looks like number 6: http://forums.pelicanparts.com/uploa...1184189971.jpg They have been in the car for about 6000-6500 miles. Any comments? |
Bump.
BTW, the car ran a lot sweeter with new plugs! |
My understanding is that with today's liquid that passes for gas you can no longer tell what is going on by looking at plug colors. I would say that number 5 looks like it has been burning some oil. Do a search on Marvel Mystery Oil as I believe some have had success with this oil additive to 're-seat' rings and such reducing blow-by and putting off the dreaded engine rebuild.
Not an expert, just regurgatating what I have heard. |
Are these the right plugs for your engine?
They look like they are running a little too hot. I would do a compression/leakdown because there is some evidence of burning oil. Also, why is there so much gunk on the threads? Do you torque the plugs with about 19-20 ft-lbs? |
I was recommended the NGK BP7, so that is what I used. The gunk may be anti seize, that I used at the time, no excessive amount.
Not sure what they was torqued to. The new plugs are the same type of plug, had them on a shelf for a year, installed clean and torqued ~200 degrees, as shown on the back of the box. Could the anti seize cause overheating of the plugs, or what was the reason for not using it? |
Anti-sieze can act as insulation between the plug and the head. The plug needs a good ground to produce a nice spark.
Not sure what it would do to the plug, but it may explain your increased performance. |
Don't slather it on. Apply A.S. equivalent to this O on clean threads. That should do it. The gasket seat should provide more than enough of a contact surface for an electrical ground path. Sherwood |
I got new plugs now. I'm going to a track day on Sunday, so I'll be putting 4-500 miles on it this weekend.
I'll check my plugs again in 1000-1500 miles and see how they are doing. My engine are euro 2.7 with 112k miles on it, no rebuild, it might need a top end soon. |
Good luck on Sunday Magnus. What track is it?
Thanks Pål!
Mantorp with PCS. Your car isn't ready for the road/track yet? |
No, my car is still has a long way to go :(
safe:
I see a piece of insulator missing on #5. Check what Porsche recommends. NGK BP7 may be a little too hot for your 2.7. I have a feeling that NGK BP6 may be a better plug for you. Anti-seize is good, use very little and do not put any on the lower 2 threads. |
| All times are GMT -8. The time now is 03:01 AM. |
