safe's Avatar
sparkplug reading help.
I just changed my sparkplugs and they look like this:
The most interesting are number 3:
and number 5, looks like it been burning oil?:
The rest more or less looks like number 6:
They have been in the car for about 6000-6500 miles.
Any comments?
Magnus
Old 07-11-2007, 02:47 PM
safe's Avatar
Bump.
BTW, the car ran a lot sweeter with new plugs!
Magnus
Old 07-12-2007, 01:48 AM
dlagerstrom's Avatar
My understanding is that with today's liquid that passes for gas you can no longer tell what is going on by looking at plug colors. I would say that number 5 looks like it has been burning some oil. Do a search on Marvel Mystery Oil as I believe some have had success with this oil additive to 're-seat' rings and such reducing blow-by and putting off the dreaded engine rebuild.
Not an expert, just regurgatating what I have heard.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 07-12-2007, 07:30 AM
Somatic Negative Optimist
Gunter's Avatar
Are these the right plugs for your engine?
They look like they are running a little too hot.
I would do a compression/leakdown because there is some evidence of burning oil.
Also, why is there so much gunk on the threads?
Do you torque the plugs with about 19-20 ft-lbs?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-12-2007, 08:07 AM
safe's Avatar
I was recommended the NGK BP7, so that is what I used. The gunk may be anti seize, that I used at the time, no excessive amount.
Not sure what they was torqued to.
The new plugs are the same type of plug, had them on a shelf for a year, installed clean and torqued ~200 degrees, as shown on the back of the box.
Could the anti seize cause overheating of the plugs, or what was the reason for not using it?
Magnus
Old 07-12-2007, 08:56 AM
Anti-sieze can act as insulation between the plug and the head. The plug needs a good ground to produce a nice spark.
Not sure what it would do to the plug, but it may explain your increased performance.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 928
Old 07-12-2007, 11:38 AM
Yes. Too much could probably do that.
Don't slather it on. Apply A.S. equivalent to this O on clean threads. That should do it. The gasket seat should provide more than enough of a contact surface for an electrical ground path.
Sherwood
Old 07-12-2007, 01:35 PM
safe's Avatar
I got new plugs now. I'm going to a track day on Sunday, so I'll be putting 4-500 miles on it this weekend.
I'll check my plugs again in 1000-1500 miles and see how they are doing.
My engine are euro 2.7 with 112k miles on it, no rebuild, it might need a top end soon.
Magnus
Old 07-13-2007, 03:32 AM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Good luck on Sunday Magnus. What track is it?
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 07-13-2007, 05:22 AM
safe's Avatar
Thanks Pål!
Mantorp with PCS.
Your car isn't ready for the road/track yet?
Magnus
Old 07-13-2007, 05:54 AM
coolcavaracing.com
Kroggers's Avatar
No, my car is still has a long way to go
Old 07-13-2007, 05:57 AM
Gunter's Avatar
safe:
I see a piece of insulator missing on #5.
Check what Porsche recommends.
NGK BP7 may be a little too hot for your 2.7.
I have a feeling that NGK BP6 may be a better plug for you.
Anti-seize is good, use very little and do not put any on the lower 2 threads.
Old 07-13-2007, 06:52 AM
