wahoofan's Avatar
A-arm bracket - which way is up?
I'm trying to put my suspension back together and can't figure out which way to put on the rear bracket for the a-arm.
It has a "flare " to it - which way is up? Does the wide end face up or down?
Please help quick - the car is already scheduled for an alignment soon!
Thanks in advance!!
wahoofan
'72 911T Targa
Old 07-15-2007, 02:00 PM
Evolved
Mo_Gearhead's Avatar
"rear bracket for the A arm"
I'm confused, just what are you describing here?
Don't fear the reaper.
Old 07-15-2007, 02:23 PM
wahoofan's Avatar
The bracket or carrier for the A-arm that the rear bushing sits in.
wahoofan
'72 911T Targa
Old 07-15-2007, 04:10 PM
Evolved
Trying to help, but lets be sure we are on the same page.
A-arm you are describing is the front suspension piece (not rear banana arm?) Correct?
The rear of that is located by the front cross member. It can only be mounted one way, the steering gear housing bolts to the top of it. What am I missing here?
Old 07-15-2007, 04:18 PM
I too am a little confused, Wahoofan. Check out the parts diagram in this link and identify the part you mean.
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_70_73_KATALOG/401-00-Frame3.htm
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 07-15-2007, 06:08 PM
wahoofan's Avatar
Never mind - I figured it out myself by matching up the rub marks on one of them. Wider end goes UP.
BTW - I was referring to the mounting brackets that are shown on either end of the A-arm(Part #12 in the above parts diagram). These are shown as part of the A-arm, but come off and are re-used if you install new bushings.
Thanks to all!
wahoofan
'72 911T Targa
Old 07-15-2007, 06:18 PM
