Karb's Avatar
Benz truck master cyl. 23.8mm m/c ??
Guys,
I found the posts mentioning this upgrade, as will as Bill V. suggesting it, but I cannot locate one with the parts number--
23.8mm m/c, ATE (ports face left) # 03-2123-3402.3.
Does anyone know where I could look for one?? My 71e, and I would prefer this route over the labor of vaccum assist.
Old 07-16-2007, 06:12 AM
Bill Verburg's Avatar
Smartracing, at the botttom of the page
I don't think Wayne carries this kit, he should
You will have difficulty fitting it unless you have updated to the later aluminum cross member
Bill Verburg
Old 07-16-2007, 06:51 AM
Remember
The Turk's Avatar
I upgraded to 993 calipers on my 75 using the Benz truck master cylinder kit, my car has the steel cross member, it is tight but mine fit without modifications.
Gary
1975 911S G50 3.5 Twin Turbo
Old 07-16-2007, 11:39 AM
Karb's Avatar
Thanks guys. EXactly what I needed to know. If wayne had it, I'd get it here. I called Smartracing, and they have it in stock w/kit.
Turk, i'm going to be using the aluminum crossmember, but you're right about the original being used. They company has instructions online, and the pictures show it mounted with the old C/member.
Link....
http://www.smartracingproducts.com/pdfdocs/642106_911_cylinderkit.pdf
Old 07-16-2007, 12:09 PM
