-   -   oxg red light indicator on dash? (http://forums.pelicanparts.com/porsche-911-technical-forum/357569-oxg-red-light-indicator-dash.html)
sabeo.m 07-16-2007 11:48 PM
Hi, i placed a new light bulb for the oxygen sensor indicator on the dash, it stays on. Is this normal? or should it turn off eventually? I didnt drive the car when i made this change, i had car running though...
Thanxs!
kepperly 07-17-2007 05:05 AM
be careful with the charge lamp when you plug it back in. The whole socket and wiring needs to stay UNGROUNDED. The red light goes off when the car starts because then the alternator is charging and there is no longer a path to ground. Both sides or leads from the lamp will short if it touches a ground and burn up the wiring either to the battery or to the alternator depending on which side touches. replacing the wiring to the lamp is a major PITA. On an 87 carrera one side goes to the shift light and the other to the alt. Keep the black insulator on the charge light or replace it with heat shrink. If the light stays on sounds like you burnt the wiring to the alternator, and the voltage is flowing to ground through the lamp.
Keith Epperly
87 slant nose turbo look carrera cabriolet
kepperly 07-17-2007 05:08 AM
Sorry not enough coffee yet, when I firsy read your post I was thinking charge lamp not an o2 sensor.
Keith Epperly
sabeo.m 07-17-2007 05:39 AM
If the wiring to the alternator is burnt, should i remove the light bulb before it causes more problems? All i did was change a simple burnt out light bulb...I remember the insulator was on the charge light properly. How do know if i damaged the alternator?
Oh Noooo! ;0(
81 911 SC 07-17-2007 12:49 PM
The OXS light was there as some sort of service reminder light I believe. You can pop out your tach and or speedo and reset the light.
Superman 07-17-2007 01:13 PM
Yes, there is a box within your dash that is a OXS "counter." It counts something like 30K miles and then illuminates that light. To reset the light (turn it off) you press the red botton on that box. The box is somewhere near the size of a pack of cigs, and is located, I believe, behind your speedo. Pull out your speedo and you should see it.
I had a clicking noise that was coming from that box. So.....I disconnected it. Well actually, I disconnected the box's ground, which had the effect of turning it off. No more OXS light, ever.
sabeo.m 07-17-2007 01:29 PM
Awesome! I'm gonna try to reset it....
kepperly 07-17-2007 05:25 PM
Be carefull with the charge light socket. If you burn the wires the car won't charge.
Keith Epperly
911Mac 07-17-2007 05:57 PM
Just reset mine two days ago. It's behind the speedo and the button was white. Mine's an 82sc.
Mac
sabeo.m 07-17-2007 07:10 PM
COOL! I just reset it...It works now! Thank's guy's!! :0)
