e p slick's Avatar
Speedo sensor dumb question #2
Car is 79 930. Speedo sensor fits in recess on right side of transaxle. Sensor has two wires that go to dedicated posts on speedo. How, exactly, do I test sensor to determine if it is working. Multimeter dial points to_____? for checking? Which wire should read what? I presume multimeter's ground indeed needs to be grounded to car. Has anyone ever experienced internal sensor stimulator (INSIDE of transaxle "going bad" or falling off? Thanks - I'm past my ability (I paint pictures for a living). EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 08-19-2007, 02:40 PM
Not totally sure how to test it but,
The speed sensor is a proximity sensor, it uses as "stimulator" a toothed wheel which is attached to the flywheel or is part of the flywheel (this wheel cannot go bad) If there is a problem it is the speed sensor that went bad or is loose and is to far from the wheel and does not give a signal. It should give a square wave signal.
Old 08-20-2007, 11:46 AM
e p slick's Avatar
sensor
Is it not Hall effect then?
Old 08-20-2007, 12:14 PM
I think it is a reed switch with 8 (?) magnets on the differential.
Interesting reading;
"smokey speedometer". smokey speedo
Rick
88 Cab
Old 08-20-2007, 12:52 PM
Remember
The Turk's Avatar
I'm pretty sure the the 79 930 speed sensor and the 87-89 G50 speed sensor work the same, it's a reed contact with 8 magnets, the sensor with two wires is located on the side of the differential by the axle.
See the bottom post in this link for a detailed explanation on how to test:
speedometer stops working
Post your results.
Good Luck.
Gary
1975 911S G50 3.5 Twin Turbo
Old 08-20-2007, 04:26 PM
