95 993 engine into 74 911
After years of looking at my 2.7 in pieces and anticipating the re-rebuild I have found a 993 engine to put in my car. The idea of it is very exciting.
My first question is what should I get from the donor car. I am getting the engine intake to exhaust, the computer and the computer wiring. Is there anything else that I should try to get like fuel pump, lines, oil cooler etc. The car is a 95 with tiptronic transmission. I do plan to use my original 915 transmission. Also ant other advise on doing this 3.6 conversion will be much appreciated. |
Engine, DME and wiring harness are all that you can use wrt a t/p. You may or may not want to use the stock headers and cat.
You will need a flywheel, ring gear, t/o bearing & associated hardware, and a conversion harness. Best to get a package try looking here Instant G A tip engine harness doesn't have the wire to run the back up lights, but it is easy to fix, talk to Steve at the above site. You may also want to think twice about retaining the stock trans.
I thought only a 3.0 would fit in that year of car?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
A 993 engine can be fitted to any year 911.
I hate to ask but why shouldn't I use the original transmission?
MBruns for President
Way to big to fit
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Your '74 uses basicly the same transmission
What I got from that discussion is that I could use the transmision if I changed the to 8:31 and change the side plates. Is that correct?
probably
Plan for suspension and brake upgrades as well. You'll need it to handle the power!
If your 74 is stock, you will need a new speedometer (74 is cable driven). |
Sports Purpose 911 Driver
there are tons of threads on this, search
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Sorry - my reading comprehension sucks - I thought you were referring to using the 993 transmission - that would be too big - yours will work - but you need to be careful with the mag case 915 trannys
drag racing the short bus
You know, I have a '74 and at one time thought about a 3.6 transplant. The recommendation of Instant G is a good one as they can inform you about everything you need. As to your transmission, I believe the 8.31 r/p is crucial to your new engine not breaking your box. Also, IIRC, Instant G recommended I replace my 15-inch wheels with at least 16-inch, 17-inch if possible. I'm not sure the wheel swap is entirely necessary as I've seen a '74 and '75 running stock wheels with a 3.6 at the race track.
Regardless, good luck with the project. Tell us how it comes out. The 993 engine is a beautiful work of art.
The Terror of Tiny Town |
IMHO: I'd say save yourself a trouble, and buy a factory 3.6 car (964 or 993). Early cars are very much fun with 3.6, but it'll be much less expansive in the end selling your car or parts and buying factory package with better components.
I'm in heaven, when I drive my nine eleven... |
Here's an idea for your transmission situation: two SC gearboxes for sale. 78 Euro SC 915 trans, and 1982 SC 915 trans
Thanks for the advise!
