10zz964's Avatar
timing help
hi guys need some help with igition timing.
how do i set ignition timing and what should it be on my engine with the following spec.
1. 2.7 JE 95:5 piston
2 weber 40 IDA
3 S cam
4 SSI
5 MSD 6A
thanks again for your help.
regards
Old 07-20-2007, 11:26 AM
I'd be pleased to offer instructions and timing values but I need to know what octane gas you use,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-20-2007, 11:44 AM
10zz964's Avatar
Thanks stve! i am using 95 (ron) octane here in Thailand
regards
instagram @tennster
Old 07-20-2007, 11:50 AM
10zz964's Avatar
posting steve answer here since he help me in early registry. in case some one search this up.
Originally Posted by Steve@Rennsport
Thank you,...
Assuming that you have a timing light and that your point gap is spot on, loosen the distributor hold-down and rev the motor to 6K for a brief moment while turning the distributor to get 30 degrees total timing. The timing marks are on the lower crank pulley, as you know.
It might take a few tries to hit the 30 degree mark and don't forget to tighten the distributor hold-down after you are done.
Thats a conservative number for your hot weather.
Hope this helps,
instagram @tennster
Old 07-20-2007, 12:09 PM
