10X17 Fuchs
I'd like to use 17" Fuchs on my soon to be 74 RS inspired 911. I know it's popular to run 9x17 and 11x17 wheels, but I'd like to have tires with more side wall showing. So, I'm thinking about 8x17 and 10x17 so I can use something like 235/40 and 285/40 tires. Since this is a street car, less rubber is not an issue.
The problem is that Lindsey Racing makes a 9.5", but not a 10" wheel.
Does anyone make a welded (no bolts showing) 10" Fuchs syle wheel?
Should I go with the 9.5" because the difference is so small?
Thanks,
Hugh
Old 07-20-2007, 08:47 AM
Friends of Warren
911teo's Avatar
On the Lindsey 9.5" you can mount up to 275 tires....
The side wall difference between a 275/40-17 and a 315/35-17 is minimal.
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 07-20-2007, 08:56 AM
Hugh,
Here is a pic of the 9.5 X 17 with 275 40's up front. This car is inspired by 74 RSR. So, I wanted side wall like you. There are some additional pics of the car in the September issue of Excellence.
Hey, I just thought of something...Your car is RS...so your flares are not as wide. My front flare is a 9" 930 flare and the 275 barely fits. In addition, I am using 930 hubs and spacers. I would speak directly with Mike Lindsey for direction.
You might consider 8's & 9.5's by Lindsey with 225 50's & 275 40's. Well..it's best to talk to Mike and research side wall height via tire rack website.
Best of luck
Paul
1970 911 (SLVR/BLK/SRD)
930 RSR in "Excellence" Sept 2007 (SOLD)
1983 911SC EURO (SOLD)
Old 07-20-2007, 09:28 AM
jjwood's Avatar
Hugh...if you wanna ck out the 9.5 & 11 x 17 w/ 275/40 & 315 x 35 look me up some time, I'm in Houston (Woodlands).
Jeremy
1971 911 Wide One 2.7
2012 911 Cabriolet
2011 Cayenne S
Old 07-20-2007, 01:30 PM
petevb's Avatar
Originally posted by PAUL RODELO
Hugh,
Best of luck
Paul
Not to Hijack, but very nice car Paul! If I read between the lines that might be a turbo in that RSR look? Care to introduce us? Looks sweet...
Old 07-20-2007, 01:50 PM
Administrator
Jack Olsen's Avatar
You can run 275's on 9.5's or 11's.
And just in case any of this thread's readers aren't clear about it, the ratio number (35, 40, 45, 50 etc.) is the sidewall size expressed as a percentage of the rated width. It's not a constant size -- it's relative to the tire's width.
But you can use the number and a tire calculator to figure out the overall diameter of the tire you're thinking about. The larger the overall tire diameter, the more sidewall you'll see. Problem is, the larger the overall tire diameter, the higher your car's going to sit in the air and the more problems you'll potentially have with tire-fender contact.
Old 07-20-2007, 02:35 PM
Here is mine with 8 and 11x17 with 235 and 315 using original 930 hubs and spacers keeping the original geometry. Michael will work with you to make it fit right.
They works great!
Old 07-20-2007, 07:07 PM
Thanks to everyone for their comments and insights. Very helpful.
Jeremy, thanks for the invite to see your wheels and tires. I'll contact you soon.
Hugh
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 07-21-2007, 07:15 AM
