source for 964 light sockets
I'm in the process of a 930 body C2 Turbo conversion and need to source the front turn signal and side marker sockets. Seems like none of the common part houses list them. Dealer item perhaps? Much thanks!
Tom
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
I ended up buying a front wiring harness to get the sockets. They exist used.
light sockets...
so, I bought the full turn signal assembly for the same app as mentioned above from dps...but there is no way to attach it to the bumper...holes need to be cut in the front fiberglass mold...this is very confusing...I need more than the housing? The sc bulbs won't retrofit?
Rob L. Currently have too many cars to properly care for
Insert Tag Line HERE.....
i got all mine from VW. I had the luxury of only needing one side, so I had the other side to compare, but they all had a small VW logo on them, so I went to the local dealer who cross referenced the number and they had them in stock. Porsche delaer couldnt find any part numbers for them.
