Drove with parking brake on...help
Drove car about 1 mile with parking brake on...car started to shudder, pulled over ASAP. Released parking brake...no more shudder...
but what did screwup this time.
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
! No biggie, just make sure your brake still holds and doesn't need an adjustment.
Well........ I hate to admit doing the same thing recently
, neither one of us is the first to have done this.So far no problems, other than shortening the life of the parking brake pads I don't believe any harm has been done. Jay
2002 Boxster Speed Yellow |
Yep... if your p-brake isn't holding very well anymore, then you might want to check the p-brake pads... otherwise no harm done.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
I did the same thing on my '89 3.2 coupe. The dash warning light cluster is not working so there I go down the road with the P-brake lightly engaged.
About a mile just like you the car starts to shudder. I though....man whats wrong. I slow down and it goes away. Speed up and major vibration/shuddering. Then I saw the handle was still in an upwards position. Dang it! Release lever and bingo no more vibrations. Everything seems OK. Although when I pulled over for a look see there was some hot brake odor and a sensation of heat radiating from the wheels. Now on every drive I do a pre-flight check and release P-brake lever. David
'89 3.2 Carrera Coupe-Silver Anniversary-sold '06 GTI/DSG |
I would at least check the brake fluid level and brake pad wear. Most likely there is no damage, but you may have to readjust the parking brake and depending on the amount of water in the brake fluid beforehand, you may want to flush the system. There is a very very remote chance that the rear rotor hats may have been distorted due to heat, but it sounds like you caught it in time.
I did the same thing, now every 300-400 miles I need to add around 18 gallons of gas!!!
I wouldn't worry about it
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
