Head light questions
Is it normal for the lenses to be almost hot to the touch after a few minutes of being on?
I have two screws on my H4's. Top side and lower side. can someone explain what each does? I've been trying to aim them with out much success.
Thanks.
Silver 1980SC Euro coupe
Old 07-25-2007, 07:11 PM
AutoBahned
RWebb's Avatar
one is up/down -- the other is side to side
don't worry re the heat, but do install relays if you have high wattage bulbs - search on 'sucro'
your owners manual should have complete directions on aiming
Old 07-25-2007, 08:30 PM
I just put in the relays so I'm good there. This car was a total restoration and now I'm just trying to tweek the little things.
I think that one of the threaded tabs on the housing is stripped. I'll pull the assembly and take a look. I'll see what wattage lamps are in there to. They get pretty darn hot.
Old 07-26-2007, 05:34 AM
