1970 911/01 Gearbox
I need help finding the correct pieces to mate this unusual gearbox up to a 1969T 2.0 engine.
I have been told due to the limited run on this gearbox I need a "special flywheel, clutch. pressure plate, clutch cable," and so on. Thanks for the help.
John '68 911 #11835176 Last edited by onephat356; 09-06-2007 at 06:26 PM.. |
70-77 flywheel, 70-86 pressure plate, 70-71 disc, 70-71 release fork, pivot bolt assembly and throwout bearing, and a 70-71 clutch cable and cable end fitting that hooks in the ear on the trans.
or just use all the 70-71 internals in a 69 case and use the 69 clutch and flywheel.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 09-06-2007 at 06:35 PM.. |
John,
Thanks for the reply. The gearbox I have is low mileage so I don't want to pop the internals out into another case. Are the output flanges with the four through bolts (long), two bolts (short) special to this gearbox as well? I have a later set of drive flanges (thanks Tony) to switch out so I can use the later axles with six long through bolts. I was also told that I should upgrade the "simplified diff" and the input shaft. What would be the reason for that?
John '68 911 #11835176 Last edited by onephat356; 09-06-2007 at 11:45 PM.. |
John has it right on.
One significant difference is the position of the clutch release arm pivot relative to the input shaft centerline. There is a significant difference between 2.0 ('69) and 2.2 ('70-'71). The alternative John is proposing is using the smaller 215 mm clutch with the original ’69 transmission. The '70 and later was the larger 225 mm clutch. Both John and I have written significantly on this subject. A Pelican search will find all that. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
John, Pelican onephat356,
A ’70-’71 type 911/01 is VERY difficult to fit in a SWB 911. I have done it on my own 911 (’68) but it is very complicated. How about some more details? The issues are: Axle connection (big deal). Clutch, another big deal Clutch operation including at the pedal assembly. and a few simpler issues. There are better alternatives to a 911/01 with more favorable gearing. Best, Grady
Grady,
There you are. I tried to send you a PM but your box was full. I got the 911/01 for a good deal from a friend so I thought why not put into my 68 roller. If the end result is no different than putting a 901 or 902 in than I will start looking for a different unit. I thought the box was kind of nifty due to the rarity now I see why.
John '68 911 #11835176 Last edited by onephat356; 09-06-2007 at 07:52 PM.. |
Hey John how's the project going? Let me know if you want a 901 gearbox.
Tony
Tony Proasi 1969S 1957 VW Pickup |
Tony,
I will let you know. I should of picked one up when my dad got the 69T engine from you. I'll be in touch.
John '68 911 #11835176 Last edited by onephat356; 09-06-2007 at 11:48 PM.. |
John,
Let me see if I can find and build you a proper 901 for your car. Wayne and I are collectin transmissions for my two chapters (901 & 915) in a book. Please contact me. Best, Grady gradyclay@hotmail.com
Grady,
Look for an email tommorow. Regards, John
John '68 911 #11835176 |
