What I'm I Doing Wrong With My CO Setting (Pic)
I received my Gunson Gas tester and wanted to set my CO to 3% after installing my new headers. I pushed down on the screw all the way and turned it many times left or right with no change at all. I'm I suppose to install an allen wrench on top and then turn it?
http://forums.rennlist.com/rennforum...id=34616&stc=1 |
Anyone :confused:
The link you post requires a login. You don't say what year your car is, etc.....
Read my reply on Rennlist.
don't frequent rennlist.....
on my 85' carrera you need to "short out" 2 pins on the rear electrical panel for the dme to not compensate for the changes, i'm sure this applys to all dme cars. |
The allen wrench did the trick... Thanks guys I managed to get it very close to 3% at idle.
| All times are GMT -8. The time now is 10:46 PM. |
