New Bleeder Valve
87 Carrera. Just finished installing rebuilt calipers and new rubber brake lines. All connections look good except for one bleeder valve that leaks. Have to tighten over spec to get it to stop leaking. Is it common to have to replace bleeder valves? Should I be concerned about the valve seat inside the caliper? Should I get a new set of four valves? Help please.
My first brake bleeding proceedure was unsucessful due to this miserable little valve (that is I hope it is the valve that is the problem).
87 Carrera Cab GP White 01 740i Sport 03 Honda Odyssey Last edited by 01sport; 01-06-2007 at 09:12 PM.. |
Re: New Bleeder Valve
You might remove the bleed screw and inspect the taper where it seals and also inspect the seat in the caliper bleed screw hole. |
Thank you for your response. Will the after market "Speed Bleeders" work as good as the "Genuine Porsche"? Set of Speeds are $25. Set of Genuine $100.
87 Carrera Cab GP White 01 740i Sport 03 Honda Odyssey |
If you are buying original and paying $100 for 8 pieces stop right now. I know where you can get genuine Brembo bleed screws for about $3 each. They will work in all Brembo calipers and every ATE caliper I have seen. |
Somatic Negative Optimist
Good advise from BertBeagle.
I found that the threads, and seat, for the bleeders on rebuild calipers need to be inspected carefully before installation. Return the caliper if the bleeder fits very sloppy or shows damage to the bottom taper.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Thanks.
1980 911 SC |
BUMP
I have found some bleed screws at a FLAPS for about a dollar or two. Just be sure to get the proper metric size (generally M10x1.0 or M7x1.0)
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
djpateman, do you know what length are they?
1980 911 SC |
Schleprock
I don't understand why Pelican's catalog has the 84-89 Carrera A caliper bleed screw at $24.75. That's got to be a mistake. There's nothing special about the bleed valves on these calipers to demand such a difference in price from the SC or any of the other bleeders they list.
Kevin L '86 Carrera "Larry" |
I have used them as well .... on my bike, BMW R11OORT. 80K mikes and no brake issues/corrision etc.
Would teflon tape wrapped carefully around the threads stop the leak? and be safe in a brake application.
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
