-   -   ignition switch (key problems) (http://forums.pelicanparts.com/porsche-911-technical-forum/359660-ignition-switch-key-problems.html)
Ducst4 07-30-2007 06:08 PM
Hi
This just happened to me, first time ever. I put the key in the ignition and the key would not turn. Just like if it was not the right key. I played with the key for 5 minutes gentle back and forth and it turned. Could the ignition switch get "loose"?
sig_a 07-30-2007 07:47 PM
First thing to try is direct spray lube injected into the key hole. Use liberally. Complete assembly is made from cast aluminum, and I think it "galls" from lack of regular lube. And the last thing you want to do is replace the entire unit at 500 dollars. I use REM (as in Remington) lube, which is made for lubricating firearms. There are a number of locks, sears, spurs in the action of O/U shotguns. Many posts here re this problem.
Zeke 07-30-2007 08:29 PM
I assume the steering wheel was not against the lock.
Super_Dave_D 07-30-2007 08:58 PM
Oh here we go....wd40 or not to wd40!!
Paulporsche 07-31-2007 06:01 AM
It could be the lock mechanism or the key. Try the lube first, then another key, then replace the switch, if necessary.
911SCfanatic 07-31-2007 06:43 AM
Had this problem 2 weeks ago before just as I was leaving for a long weekend. I was stuck in my garage with 500 miles to drive that day. WD40 and problem gone.
