-   -   Backdated Dash ? (http://forums.pelicanparts.com/porsche-911-technical-forum/359699-backdated-dash.html)
EarlySport 07-31-2007 12:03 AM
Backdated Dash ?
Hi All,
I'm about to embark on an 82SC to 74 IROC conversion, and I'm keen to backdate the dash to the early style. Has anyone done this and can share some tips? basically I'd like the heater controls and radio to be in the same horizontal plane, with the aluminium trim surrounding them... ( I'm assuming this is what a 74 had - I use my 69 as a reference ).
Thanks.
Craig H.
_____________________________
69 911E RS Replica 3.0L 915 Webers
93 968CS
82 911SC Soon to be IROC RSR 3.6L
Dutchie 07-31-2007 02:42 AM
Graig i think 74 was the year they changed to the "newer type" interior like on your SC. I think an SC dash would look more period correct than a 69 dash.
bump for the experts :)
eimkeith 07-31-2007 04:08 AM
yeah - it's all the same underneath. Just change all the covering stuff (which will cover the vents)
ERH 07-31-2007 04:10 AM
Originally Posted by EarlySport (Post 3403480)
Hi All,
Thanks.
Craig H.
93 968CS
I can't comment on "correctness" but Keith is doing a dash back date on a C2 on this thread and I'm sure he can help....
http://forums.pelicanparts.com/porsche-911-technical-forum/318580-zuffenhaus-c2-72-rsr-project.html?highlight=eimkeith
ERH 07-31-2007 04:11 AM
Must type faster :)
PcarPhil 07-31-2007 04:33 AM
I've been planning on doing this with my backdated '81 chassis (morphing into a '73 RSR creation).
It sounds like a '69-'73 dash pad is a direct bolt in?
EarlySport 07-31-2007 05:54 PM
Thanks for the feedback guys. I'm going to go searching for some pics of an original 74 RSR dash. Feel free to post one here!
That said though, I really find the simplicity of the early ( pre-73 ) dash much more appealing than the SC dash. Why is the heater control panel offset upward in the SC?! Although I've just realised, that maybe only us RHD guys that have dash like this....
Craig H
TRE Cup 07-31-2007 06:26 PM
on lhd cars, it is a simple matter of obtaining the aluminum face trim, removing the foam, and attaching the early trim to your dash. the glove box door cover on lhd cars needs to be milled slightly to clear the lock. The early fresh air controls swap out as well. There could be some detail differences on hole location, but that is a minor concern as the early alloy trim uses the vinyl insert (which can cover it). You will need to source the early knob centers for the switches. The turn signal switch and wiper switch can be replaced with correct 74 bits too
Finally , the guages can be refaced to match the 74 RSR
Tim K 07-31-2007 10:09 PM
I can't comment on the RHD vs. LHD, but maybe these images will help.
Early dash in an SC:
http://forums.pelicanparts.com/porsche-911-technical-forum/314917-dash-swapping.html?highlight=dash
Tim
EarlySport 08-01-2007 07:25 PM
TRE Cup hit the nail on the head. I need to source some early dash aluminium trim pieces.
TRE Cup 08-02-2007 09:29 AM
hello early sport
You are doing a 74 IROC backdate conversion?
My bad:
just re-read your first post: the 1974 model used the foam paneling on the dash with a single lever upper (of the three levers) on the fresh air control. There are some logo differences on the knobs , but they are the same as the 82.
The turn signal and wiper switches were aluminum "wand" versus the plastic paddles that the 82 had. Pelican may have them available. The dashpad itself is supposed to be the version with no center vent, but upper speaker grill. The end vents on the dash are the same as the 82. A factory radio block off plate is available (we stock them). The fasten seat belts indicator lamp is a smaller single row unit than the 82 (which shows the brake indicator as part of it)
