Need some Transmission Help Please
Hey All,
I seem to having a bit of trouble with my 1990 911 C2. She is running beautifully, however, I seem to be running into a transmission or clutch issue. I could use some advice..
When the car/tranmission is cold, the gears shift into place easily, and smoothly. Clutch feels good, and all is well.
After a good bit of driving (30 mins of stop and go) or 30 mins on the highway things start to change. If I let my car come to a complete stop, and go to shift into 1st, its very difficult to engage. Its as if something is blocking the gate from pushing the shifter up into first. If I quickly double clutch, it seems to help quite a bit and the shift will snik into gear. Also, if the car is moving (even very slowly) I can shift it into gear no problem.
I recently had my clutch fluid bled...didnt seem to help.
Anyone experience this, and have a diagnostic and fix for the issue? Is this normal behavior for a 1990 964 with all the updates? My clutch should still be good, and doesnt seem to be slipping at all when accelerating hard...
Any help would be appreciated,
Jack
Old 07-31-2007, 06:49 AM
burgermeister's Avatar
I don't have too much experience with 911's (yet), but generically it sounds a bit like a lightly dragging clutch... easy to check: jack up the rear, put it in 1st, press the clutch, and see if the wheels still spin.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 07-31-2007, 09:31 AM
