Lube it up good with some grease and hit it with a scotch brite pad also
parts list say No longer avail. I wouls say try Oklahoma Foreign for the part
OK here is what happened...
I took the switch and pin out as I said above... I cleaned them and tested the switch agn... it still looked fine??? I thought if anything the pin may be sticking in the area is rides in because there is no way it can ride any where but center with the design.. but like all things that ride on a cam lobe of types they get distorted over time... my thought was to file the edge of the bottom that sits on the cam and what I did was just give it a slight roundness... well I put it back in and tested it and all is good.. I put it in reverse and lights on and took it out and lights off... I did this about 25 times so we will see how it works over the next few days or so... The blower as I said above works now I just need a relay and a cover for the relay panel... Also need the contact switch for between the seats... would rather replace it as I found it for 13 bucks. Tom said I could return the 2 relays for a 25 dollar credit or refund... So I will send them out Thursday or Friday.... I am going to continue to test pics of the pin and switch: http://forums.pelicanparts.com/uploa...1186522705.jpg http://forums.pelicanparts.com/uploa...1186522722.jpg thanks guys... if all is well Iwill be moving to the cab top next... |
13 bucks make sure its the correct year 77 and older is different type
http://www.pelicanparts.com/cgi-bin/...161352120-M100
901-613-521-20-M100 Contact, 911/911 Turbo 1974-89 $13.00 $13.00 pretty sure this is the one.... |
Does that look like what you have I thought it was more of a micro switch
yup that looks like it... pretty simple design... I will try to get a pic of it for you...
Good deal I might have to get one too I dont quite know what Im going to do for defrost heat yet but I will probably wire it thru the stock location whatever I do.
| All times are GMT -8. The time now is 10:28 AM. |
