-   -   airbox mod (http://forums.pelicanparts.com/porsche-911-technical-forum/359992-airbox-mod.html)
84porsche9113.2 08-01-2007 01:31 PM
airbox mod
I was just wondering if rather than cutting the cover, has anyone simply experimented with just leaving the entire cover off and duct taping the filter in? Only reason I'm thinking of doing this is because I have some adjusting and testing to do on my car which will require me to pull the AFM and airbox cover in and out several times. It would seem to me that the easiest way to do this would be to leave the cover off, duct tape the filter in, and leave the fastners on the inner part of the air box off. This way I only have to undo one hoseclamp and the whole afm and inner box will come out quite easily, rather than having to remove the cover and/or undo the nuts every single time.
Anyway, I was wondering if it could be a semi-permanent solution as well or if anyone has tried it. Seems to me like something a raciing team might do but I don't race so I have no clue. Even if it is only temporary, at least I would be able to hear what the air box mod (cutting away the top portion of the cover) might sound like by having the filter duct taped in and no cover....
azasadny 08-01-2007 01:36 PM
I've seen someone who used large plastic tie-wraps to attach the air filter to the airbox and then left the cover off... that might work for you...
84porsche9113.2 08-01-2007 01:44 PM
hi azasadny, thanks for the tip. do you know how the ties were attached? did they drill through the air filter and cover to get the wraps through or did they just somehow tie wrap the corners so no drilling necessary?
kimlangley7 08-01-2007 05:28 PM
I've seen several pix of guys just cross -attaching the OEM bungie straps >> a big "x".. keeps the air filter in place
Oh Haha 08-01-2007 06:54 PM
Here's how I run mine.http://forums.pelicanparts.com/uploa...1186019656.jpg
Charlie V 08-01-2007 09:11 PM
Originally Posted by Oh Haha (Post 3406766)
Looks like a "strap on". I like how you have done the heater tubes and eliminated the blower motor junk. Smart thinking.
gerard vaglio 08-01-2007 09:33 PM
I experimented with this a while back. Here is everything you've ever wanted to know about airbox covers.
Yes, you can run just the air filter, you can also cut the top off like I did and run the bottom of the cover as a frame that holds the filter tight against the airbox with the stock straps. I thought this solution looked very cool.
2 problems with this that you should know about though. First, if it rains, water can make its way into the throttle body. Second, the bottleneck for air entering the engine isn't the filter, its the throttle body behind the filter. The filter actually has a lot of surface area to it.
So, there won't be any noticeable difference in performance when you alter the air box cover but there is still a lot of mythology out there around air box covers. You can achieve a different sound by altering the cover and some people do like this sucking sound. Adds to the drama.
I purchased a larger throttle body from SCarGo years ago, that might be another path for people looking to improve this area.
Lastly, if you still want to alter the cover but avoid problems on rainy days you can drill a series of one inch holes along the bottom of the cover right above the lip. This lets in more air but keeps the filter out of the path of any rain.
I've run this "modification" for several years without a problem. Again, the benefits are mostly in your mind but hey, if your having fun who cares.
gerard vaglio 08-01-2007 09:47 PM
Oh,Haha, since I'm dispensing unsolicited advice this evening if you wanted another option to the tubing your running across the top of your engine you can do a search under backdating the heat.
You can purchase the parts on the parts lists you'll find used and you could eliminate almost all of that tubing. You'll be much happier with the results as you'll have more room to work and your heat will be better as well.
Okay, my work is done here.
Javers 08-02-2007 04:03 AM
I went down the route of "topless" airbox aswell. Picked up a spare off ebay and went to work with the jigsaw mimicking the fabspeed one. I left as much at the top as I could to act as a bit of a rain lip, I'm pretty happy with the way it turned out, and does free up a bit of space in the engine bay.
http://i78.photobucket.com/albums/j1...thumbnail2.jpg
http://i78.photobucket.com/albums/j1.../thumbnail.jpg
Jon
Dixie 08-02-2007 04:50 AM
I too simply bought a used lid, and cut it up. It offers no more power, but I like the sound.
http://forums.pelicanparts.com/uploa...1186055066.jpg
Wil Ferch 08-02-2007 05:35 AM
I don't get it....
I did the mod that Javers and Capt. Carrera did....section the lid to have only a 1" wide band left. This leaves the 4 clips very easily accessible and takes what?....3/4 or fully 1 minute to unfasten? Ductape? Ductape?
- Wil
DeutschMark 08-02-2007 06:32 AM
Duct tape?
khamul02 08-02-2007 09:07 AM
Check this out. It goes for a couple hundred from PP
http://cgi.ebay.com/ebaymotors/1973-1983-Porsche-911-Performance-Track-Airbox_W0QQcmdZViewItemQQcategoryZ43946QQihZ004QQi temZ140142970094QQrdZ1QQsspagenameZWDVW
euro911sc 08-02-2007 10:41 AM
hahahahahahahahaha
+10 hp....
hahhahahahahaahaha
You know, one could make a frame out of some 1/2" pine wood in about 5 minutes for less than $5... and the K&N...
FYI spoke with a pretty fast F stock guy running an ROW SC... tested K&N vs stock on the local dyno... K&N lost 6 hp so he did the test again ... same ... he tells all his F stock buddies to run K&Ns :) YRMV (Your Results May Vary)
Best regards,
Michael
