-   -   Chip Problem? (http://forums.pelicanparts.com/porsche-911-technical-forum/360173-chip-problem.html)
rde 08-02-2007 03:35 PM
Chip Problem?
I installed a Steve Wong chip in my 88 cab a few weeks ago. Great boost in performance! However, lately the car will lug (i.e. buck) at low RPM's and will also occasionally smoke at start-up and smoke when engine is cold and leaving from a dead stop.
Engine has 70K miles and I didn't have these issues with the stock chip. Any ideas?
gr8fl4porsche 08-02-2007 03:46 PM
Did you change the oil or top it off recently?
rde 08-02-2007 04:27 PM
Yes, dealer changed oil recently. But wouldn't too much oil have showed up as a problem right after the oil change? The smoking didn't start until after I installed the SW chip.
88-diamondblue 08-02-2007 08:41 PM
Email or give SteveW a call. His customer service and knowledge on this is second to none.
Jeff Alton 08-02-2007 09:33 PM
Did you change the chip back to see if it cured the problems up?
Cheers
JeremyD 08-03-2007 07:25 AM
Did you take the catalytic converter off when you installed the chip? Sometimes (it did with my car) the catalytic converter can mask the smoking at start up and leaving from a dead stop (after being run hard)
Mine ended up being worn valve guides (at 56,000 miles)
Por_sha911 08-03-2007 05:42 PM
Check your oil just to rule that out. Then switch back to the stock chip and see if it goes away. Lastly, call Steve. He's a great guy and will bend over backwards to make sure you are happy.
