Chip Problem?
I installed a Steve Wong chip in my 88 cab a few weeks ago. Great boost in performance! However, lately the car will lug (i.e. buck) at low RPM's and will also occasionally smoke at start-up and smoke when engine is cold and leaving from a dead stop.
Engine has 70K miles and I didn't have these issues with the stock chip. Any ideas? |
Did you change the oil or top it off recently?
Randy '87 911 Targa '17 Macan GTS |
Yes, dealer changed oil recently. But wouldn't too much oil have showed up as a problem right after the oil change? The smoking didn't start until after I installed the SW chip.
3.4 Bigger is better
Email or give SteveW a call. His customer service and knowledge on this is second to none.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Did you change the chip back to see if it cured the problems up?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
MBruns for President
Did you take the catalytic converter off when you installed the chip? Sometimes (it did with my car) the catalytic converter can mask the smoking at start up and leaving from a dead stop (after being run hard) Mine ended up being worn valve guides (at 56,000 miles)
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Make Bruins Great Again
Check your oil just to rule that out. Then switch back to the stock chip and see if it goes away. Lastly, call Steve. He's a great guy and will bend over backwards to make sure you are happy.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
