-   -   Just another 915 question (http://forums.pelicanparts.com/porsche-911-technical-forum/360619-just-another-915-question.html)
dbrisson 08-05-2007 07:23 PM
Background
1982 SC runs well, the clutch adjustment is out since I cannot set it to match the 101 projects book. It appears the adjuster and the throwout release shaft were seized together. I tired pb blaster with some effect but it still appears to be binding. I am guessing complete disassembly clean and check for bad parts. It will eventually sooner than later need a clutch plate because of this.
I get what from forum searches appears to be the typical high rpm buzz or grind between 1 and 2. Everything else is fine. With generic 90wt it appears to be less frequent, with the current swepco it is more noticeable or happens more often. I tried double clutching which really just lowers the rpm enough for it not to happen.
I have not adjusted the shifter nor replaced the couplers or bushings.
Questions
Should I go through the coupler wevo or generic replacement route and bushing replacement before thinking of the 915 removal?
Is it just a destined fact the synchros are going bad? If so I guess this is going to be a winter project.
Could the clutch linkage issues be the root of the problem?
Thanks for any insight...
dlagerstrom 08-06-2007 08:08 AM
I would definately replace bushings in the shift linkage before planning a tranny rebuild. The bushings will need to be sorted out anyway and don't cost very much. I just replaced the 1/2 synchro parts on my 915 and it was well over $1000 just for the parts.
Many have posted about the positive effects just sorting out the shift linkage has done for them. That and careful shifting may hold off a tranny rebuild for some time.
