-   -   DIY rustproofing using LPS3 (http://forums.pelicanparts.com/porsche-911-technical-forum/360998-diy-rustproofing-using-lps3.html)
jzeeff 08-08-2007 08:20 AM
I have had great results with using LPS3 to keep corrosion off of any steel car part. I use it under the hood, in the doors, underneath, etc. I buy it by the gallon.
As it dries, it forms a tough waxy coating.
In exposed areas, it lasts a year or two. In contained areas, it seems to last forever.
I've definitely seen it completely halt corrosion in progress.
azasadny 08-08-2007 08:58 AM
Where did you buy the LPS3? In Ann Arbor or online?
Porsche_monkey 08-08-2007 11:16 AM
We use that stuff on machined surfaces when we ship overseas. It works really well, even saltwater won't cause corrosion when you properly coat something with it.
Bobboloo 08-08-2007 02:02 PM
Thanks for the info.
jzeeff 08-09-2007 12:37 PM
I bought it online from some aircraft supply place. Given the cost of airplanes, owners really take care of theirs.
joefrantz 08-09-2007 10:55 PM
The LPS Procyon product looks interesting too. The description says it dries to a hard transpaent finish. Does anyone have experience with it?
Joe
EarlyPorsche 08-10-2007 06:27 AM
How is your join date earlier than when the dinosaurs were alive?
Blue3.2 08-10-2007 11:32 AM
FYI, Grainger (www.grainger.com) sells it for about $12/can.
Also, a distributor list is available at http://www.lpslabs.com/dist.asp.
Haven't used it yet, but I'm going to pick some up today.
CliffBrown 08-10-2007 05:49 PM
I used LPS 3 as a corrosion preventative in General Aviation aircraft with good results.
