DIY rustproofing using LPS3
I have had great results with using LPS3 to keep corrosion off of any steel car part. I use it under the hood, in the doors, underneath, etc. I buy it by the gallon.
As it dries, it forms a tough waxy coating. In exposed areas, it lasts a year or two. In contained areas, it seems to last forever. I've definitely seen it completely halt corrosion in progress. |
19 years and 17k posts...
Where did you buy the LPS3? In Ann Arbor or online?
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Slumlord
We use that stuff on machined surfaces when we ship overseas. It works really well, even saltwater won't cause corrosion when you properly coat something with it.
Warren Hall Student
Thanks for the info.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I bought it online from some aircraft supply place. Given the cost of airplanes, owners really take care of theirs.
The LPS Procyon product looks interesting too. The description says it dries to a hard transpaent finish. Does anyone have experience with it?
Joe
Joe Frantz 73 911 T |
How is your join date earlier than when the dinosaurs were alive?
FYI, Grainger (www.grainger.com) sells it for about $12/can.
Also, a distributor list is available at http://www.lpslabs.com/dist.asp. Haven't used it yet, but I'm going to pick some up today.
'86 Porsche Carrera Coupe |
Old Member
I used LPS 3 as a corrosion preventative in General Aviation aircraft with good results.
Clifton Brown https://www.mancalamarketing.com |
