911 missfire problem
Could anybody give any input as to what could be causing a missfire on my 1979 sc. I took it out on the road yesterday and she was fine,so got her out of the garage today and washed and waxed the bodywork and now when I try to accelerate she runs really rough. When i was using the hose I was careful not to get too much water in the engine area. Any ideas where I should start to look for the problem.Many Thanks
Driving member
You may have a crack in your distributor cap. If so it doesn't take much water to make it misfire.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
If nothing happened except the washing, I would agree with Jerry. You could even have a "leak" in one of the high tension cables or connectors that will misfire with very little encouragement. Dry all electric parts thououghly and try again.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Driving member
If you really want to get down to it let the car idle with the deck lid open. Preferably in the dark
take a spray bottle of water and give it a shot towards the dist. cap and wires. If you have a light show then you have found your leak.
thanks guys, I have only had the car 2 years and only run it in summer,so I may go and change the cap, rotor,plugs and HT leads. Thanks Again
Please read the following thread all the way through, then check the green coax signal cable from the distributor on your engine:
coil to buy question
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks man ,I will look into the green wire more closely.
It appears that a small amount of water is causing your ignition wires to short out too easily meaning your ignition wires may need to be replaced.
Cheers, Joe |
