-   -   Fast turn signal (http://forums.pelicanparts.com/porsche-911-technical-forum/361161-fast-turn-signal.html)
valleley 08-09-2007 07:13 AM
Fast turn signal
Hello My fellow Porsche owners,
I have a fast left turn signal and the front light works but does not blink.
I have a new bulb and relay installed.
Can anyone think of something else.
jester911 08-09-2007 07:15 AM
Usually one of the bulbs is out when it blinks quickly. Either front or back.
cgarr 08-09-2007 07:16 AM
Check the grounds
kplackmeyer 08-09-2007 07:20 AM
Be certain you have the proper bulb in there. Sounds silly, but I have seen a 2 filament bulb in a single filament socket, and vice-versa. Can make all kinds of weird things happen.
pmajka 08-09-2007 08:16 AM
If you have replaced the bulbs, check the thin wires in the head light buckets for corrosion or connectivity..
happens every time i pull out the head light.
Porsche_monkey 08-09-2007 09:04 AM
Check that your bulbs are not low-wattage. The circuit will not work with the low wattage bulbs because the coil needs a minimum current to operate properly.
Do search, but I think low wattage are 15watts and you need 21 watt bulbs.
Also, you should specify your vehicle and year in your signature, or in your post. If you have a 1977 Lada my advice should be ignored.
