oly oly is offline
1985 Carrera Coupe
Question Moving 3.2 Carrera inboard seat belt receptacles from seat to tunnel or floor
Does anybody have any ideas for this? I'm especially interested in seeing pictures of installations.
I want to move the original seat belt receptacles from the seat to the tunnel or the floor in my 3.2 Carrera. The reason is that I'm using a racing shell seat connected to the car mount points with brackets (no sliders). Since the seat belt receptacles mount to the original seat, I need a new mounting location for them.
So my goal is to transfer the seat belt load to the car body in a way that makes acceptable stresses along the whole load path. I also want the location to be at about the same fore / aft location as the outboard seat belt mounts. This rules out using the car mount points. These are the options that I can think of so far for mounting:
1. on tunnel using welded on doubler plates -
PRO excellent load transfer (same as on the SC),
CONs welding near the fuel lines inside the tunnel is dangerous
2. on tunnel using bolted on doubler plates -
PROs can do myself & doesn't require danger of welding,
CON will add hard metal pieces to the inside of the tunnel that could chafe on fuel lines
3. on floor using welded on doubler plates -
PRO excellent load transfer,
CONs have to retreat area for rust protection
4. on floor using bolted on doubler plates -
PRO can do myself,
CON holes in the tub
Art
Old 07-27-2007, 02:32 PM
don911's Avatar
I looked at this before and didn't find a good solution. I'm using brey krause seat belt anchors with my race seats. When you figure it out, please post.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 07-27-2007, 04:50 PM
oly oly is offline
1985 Carrera Coupe
don911,
Are you using the BK R-9005 seatbelt mounts? Did you just bolt them on the aft most holes of the factory mounts?
Art
Old 07-27-2007, 05:34 PM
Irrationally exuberant
ChrisBennet's Avatar
I made a U shaped bracket similar to those in an pre-85? car with a backing plate that went inside the tunnel.
-Chrrs
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-27-2007, 06:44 PM
don911's Avatar
Originally Posted by oly View Post
don911,
Yes, R-9005. I tried it both ways. I'm using sliders so I have it mounted between the slider and the side mount same as it was with the factory seat.
Also, I have one factory anchor bracket from a non powered seat sitting in the garage if you want it. Here's a picture of my set up. I currently have an eye bolt installed for my harness.
Don
Old 07-27-2007, 08:21 PM
I think the factory seat receptacle floor bracket is U-shaped and welded to the tunnel.
Instead, I used a short length of trailer hitch square tubing. Drilled vertical holes to place a 1/2" thru- bolt into the floor. Back it up with a large diameter hardened (seat belt) washer and nut. Cross holes in the bracket attach the factory seat belt receptacles with a single bolt and lock nut. Use large dia. Nylon washers on either side of each receptacle so they can easily rotate around the bolt without flopping around.
Sherwood
Old 07-27-2007, 09:01 PM
Jeff Alton's Avatar
Here I go to the garage to take a pic....................
Cheers
www.turn3autosport.com
Old 07-27-2007, 10:13 PM
Jeff Alton's Avatar
Okay, back from the garage.....
These are in my 84, and they are welded to the tunnel from the factory. I run eye bolts in them for the harness and the factory seatbelt receptacle.
Cheers
Old 07-27-2007, 10:20 PM
Driving member
jester911's Avatar
I don't have pics but I can take some if needed. I have seat brackets that have the seat belt brackets welded to them. They are Corbeau brackets and they come this way.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 07-28-2007, 04:16 AM
oly oly is offline
1985 Carrera Coupe
Thanks for the posts everybody!
Art
Old 07-29-2007, 09:54 AM
oly oly is offline
1985 Carrera Coupe
ChrisBennet,
Can you post a picture of your U shaped bracket? I assume that it is inverted and that the vertical parts of the U bolt to the vertical parts of the tunnel. Is that right?
Art
Old 07-29-2007, 09:56 AM
oly oly is offline
1985 Carrera Coupe
don911,
I've got the same problem when I use R-9005s; they put the receptacle too high for the seat belt slot in the seat. My additional problem is that even in the most aft position on the car mount, the R-9005 is forward of the seat belt slot in the seat.
Art
Old 07-29-2007, 10:00 AM
oly oly is offline
1985 Carrera Coupe
911pcars ,
Your installation sounds like a good one. Would you mind posting a picture?
I assume that the "large diameter hardened (seat belt) washer" are more of a precison looking washer than the common stamp cut washers. Is that right? Where did you find the hardened washers? I've done some looking on the McMaster Carr website and the Grainger website but haven't seen anything other than what lookes like normal stamp cut washers with relatively big tolerance on their thickness.
Art
Old 07-29-2007, 10:13 AM
oly oly is offline
1985 Carrera Coupe
Jeff Alton,
That looks like a stout installation. How did you do the welding and not get the fuel lines too hot?
Also, what is the purpose of that rod running through both pictures?
Art
Old 07-29-2007, 10:16 AM
oly oly is offline
1985 Carrera Coupe
jester911,
Mounting the seatbelt to the seat bracket would be convenient. But I heard that some inspectors would not accept that load path for DE or racing. Have you had any issues with that?
Art
Old 07-29-2007, 10:19 AM
Driving member
jester911's Avatar
No problems with DE. I don't do W2W with my car but I have done several DE's with the PCA without any problems.
Jerry
Old 07-29-2007, 10:29 AM
oly oly is offline
1985 Carrera Coupe
Everybody,
Has anyone ever seen or considered mounting the receptacles to a piece of metal that cantilevers off of the top inside of the seat mount brackets? Specifically, the seat mounts that are welded in the car, the car floor, and the car tunnel form a rectangular channel that runs fore/aft. The channel is about 1" wide and 3" high. The seat attaches to the top outside of that tunnel. It seems like I could bolt a long bar of metal on the top inside of the tunnel; one bolt at the front seat mount and one (or two) bolts at the aft seat mount. The bolted in bar could extend past the aft end of the seat mount channel and give a rigid mounting location of the seat belt receptacles. I like it because it would not require permanent tub changes like drilling or welding would.
Art
oly oly is offline
1985 Carrera Coupe
jester911,
Okay, thanks!
Art
Old 07-29-2007, 10:35 AM
ChrisBennet,
I think the offset holes for the belts is key. This allows them to belts to swivel.
The crappy welding of the nuts on the backing plate is the my first (and only) attempt at welding.
With this arrangement, I had my factory seat belts and racing harnesses lap belts attached to the same bracker. A lock nut kept things from loosening.
-Chris
Old 07-29-2007, 10:47 AM
Driving member
jester911's Avatar
Art, what you describe is not much different from the Corbeau seat bracket.
Do you have a roll bar or cage?
Jerry
Old 07-29-2007, 10:48 AM
