-   -   69 - 71 MFI magstacks the same? (http://forums.pelicanparts.com/porsche-911-technical-forum/361324-69-71-mfi-magstacks-same.html)
al lkosmal 08-10-2007 08:57 AM
Does anybody know if the 69E and 71E used the same part number MFI magstacks. What's the part number for the 71E?
thx,
al
andrew15 08-10-2007 09:21 AM
Hi Al -
I believe that the stud spacing on the throttle body / stack interface was different. 69 had one spacing and 70-73 had another spacing.
That said, the stud spacing on the heads was the same so you could use a complete 69 throttle body/stack setup on a 71 or vice versa.
Regards,
Andrew M
al lkosmal 08-10-2007 09:27 AM
Andrew,
thanks. Do you know of a source that lists the part numbers?
al
1972_911T 08-10-2007 09:33 AM
You can tell the 69 stacks because they are the only year to use a 901 pn all the later ones had a 911 pn.
Some good info here http://forums.pelicanparts.com/porsche-911-technical-forum/117171-mfi-induction-chart.html?highlight=mfi
