69 - 71 MFI magstacks the same?
Does anybody know if the 69E and 71E used the same part number MFI magstacks. What's the part number for the 71E?
thx, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Hi Al -
I believe that the stud spacing on the throttle body / stack interface was different. 69 had one spacing and 70-73 had another spacing. That said, the stud spacing on the heads was the same so you could use a complete 69 throttle body/stack setup on a 71 or vice versa. Regards, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Andrew,
thanks. Do you know of a source that lists the part numbers? al
You can tell the 69 stacks because they are the only year to use a 901 pn all the later ones had a 911 pn.
Some good info here MFI Induction Chart
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 Last edited by 1972_911T; 08-10-2007 at 09:36 AM.. |
