Spacers or Adaptors
I am planning to increase the rear track on my Carrera by an inch or so to fill the wheelwell when I install 16's instead of the 15's it came with.
I can do it with spacers and longer studs or with adaptors to which the wheel is bolted and which is in turn bolted to the hub.
Any thoughts on which way to do it?
Old 08-14-2007, 10:07 AM
David's Avatar
You won't have change wheel studs with the adaptors, so that would be my choice.
Old 08-14-2007, 10:58 AM
Model Citizen
herr_oberst's Avatar
spacers are safer
Old 08-14-2007, 11:01 AM
cycling has-been
bkreigsr's Avatar
anything you add will be additional unsprung weight
factory spacers are the lightest
aftermarket adapters carry around 2 of everything, (studs and nuts)...very heavy
Bill K
Old 08-14-2007, 11:40 AM
Platinum Member
dad911's Avatar
Have you purchased the 16's yet? If not, get wheels with the proper offset, and use neither.
Are you going to track the car? I would not use adapters on a track car.
Old 08-14-2007, 12:02 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
I got adapters...I check the torque on them twice a year just to make sure...never had problems with...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 08-14-2007, 12:15 PM
KTL KTL is offline
Schleprock
KTL's Avatar
That's the best advice right there. Then if the wider wheels still don't fill out enough, you can use lesser spacers with longer studs. You then end up with more desirable wheels and less spacer.
Kevin L
'86 Carrera "Larry"
Old 08-14-2007, 12:53 PM
Less brakes, more gas!
euro911sc's Avatar
Talking
I'm pretty sure that adapters are not legal tech for DE/Club Race. Spacers are... goes to checkability of the entire mount of wheel to hub thing...
This may spec you what you need.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-14-2007, 03:15 PM
