Engine stand hole spacing?
I ordered this engine stand today and I would like to find out the mounting hole spacing so I can build a roll around base and have it ready when it arrives. Could someone take some measurements of theirs and pass them along? It would be a big help.
http://www.pelicanparts.com/catalog/shopcart/911L/POR_911L_TOLtol_pg1.htm#
Here is the part number: PEL-TOL-SIR313
Thanks,
Bob
Old 08-13-2007, 10:30 PM
Less brakes, more gas!
euro911sc's Avatar
Just curious, are you mounting it to a bench as well? If so, how will you ensure it does not fall over/pull out of what ever you mount it to etc etc etc??
Thanks,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-14-2007, 03:27 PM
I plan to build a normal engine stand with four wheels and at the top there will be a plate with holes drilled for attaching this unit. The unit will be made from steel and welded together like this:
TOL-OTC2012
Old 08-14-2007, 03:45 PM
MBEngineering's Avatar
HI Bob do not skimp on the thickness of the mounting, like this;
the size is ;8.5/8"x 11.3/4"x 3/8 thick, the hole spacing is 170mm across x 140mm lengh
the reason for the bit at the back is some where to put tools/parts/magnetic bit's tray
if you make a stand like this you can then bolt to the floor, or make a mobile stand to fit the base out of 3 sections of box.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 08-15-2007, 03:37 AM
