umfan866's Avatar
Send a message via AIM to umfan866
Tuning a modded engine to pass CA smog?
I'm looking at a 1987 911 3.2 /G50 with recent top-end rebuild and these mods:
Upgrades
964 cam upgrade
SSI headers
Dansk Sport Exhaust
Downgrades
Catalytic converter has been removed
Could this 911 be tuned to pass CA smog? I know that it may fail visual inspection, due to the SSI's but apparently some people can tell the smog person that it is a "dual cat" system when he/she questions it.
However, could one adjust the mixture to actually pass the pipe test, including the more recent one on the dyno?
2016 Honda Civic LX in White
2015 Honda CRV EX in Black
1987 Porsche 911 3.2/G50 Targa in Guards Red *SOLD*
2005 Honda Odyssey LX in Gold *SOLD*
1986 BMW 325 in Black owned for 21 years *SOLD *
Old 08-14-2007, 03:23 PM
Give S-Car-Go and/or Porboys a call. Keep in mind that the mixture cannot be adjusted on a Carrera without changing the DME software.
Old 08-14-2007, 03:29 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I have heard that it helps if one injector plug isn't properly seated....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-14-2007, 03:37 PM
RETIRED
Joe Bob's Avatar
You need a cat to pass the visual inspection. Best to see how it does on the pipe test PRIOR to going to the smog test. Getting tagged as a gross polluter sends you to the BAR and THEY run engine numbers.
Test it, HOT and if it passes..... then take it to a "Billy Bob" tester that does Chevies....they will probably miss the lack of cat.
2012 ML350 3.0 Turbo Diesel
Old 08-14-2007, 05:50 PM
ianc's Avatar
Idle mixture can be adjusted via a 3 mm allen screw in the AFM. Off-idle mixture can be adjusted via some finagling with the flapper spring tension once the AFM's cover has been removed. A properly functioning O2 sensor should be able to correct unless the engine's at WOT however,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 08-14-2007, 10:13 PM
umfan866's Avatar
Thanks guys!!
Hey Ian - hows it going?
I talked to the seller today, and he said that after all these mods, it still passed the Washington state smog test without the cat at all!!!
The bad news is that at this point another buyer has gotten to it first, and is having the PPI done, he's also from the Bay Area. So we'll see I'm not as worried about smog now.
Old 08-14-2007, 10:29 PM
