-   -   Looking to clean up wiring in engine bay, help? (http://forums.pelicanparts.com/porsche-911-technical-forum/362246-looking-clean-up-wiring-engine-bay-help.html)
FirstGen 08-16-2007 08:16 AM
I am wondering where I should start looking for a good color coded wiring diagram for the engine bay area of my 77 911? The wiring has been doctored a few times by the PO's and I would like to clean up the mess. I figured now would be the time while the engine is out...
I'm mainly just trying to figure out what does what so that I can isolate what I do and don't need from this mess.
Any help is appreciated!
gsmith660 08-16-2007 08:22 AM
he haynes 911 repair manual has color coded wiring diagrams should be able to order one from your local auto parts store.
FirstGen 08-16-2007 08:47 AM
Ok I'll into one. Thank you.
Dan in Pasadena 08-16-2007 11:00 AM
You also need to see an underhood restoration job thread done by Fishcop here. If I remember correctly, he installed a replacement modern fuse block and generally cleaned up his entire front wiring system, including paint. Truly impressive and though labor intensive didn't look all that difficult. Anyway, do a search for "Fishcop" as the author.
Evans, Marv 08-16-2007 11:15 AM
Check out the wiring diagrams on the home page here. If I remember correctly those are color coded & probably cover your car.
